The picture I am receiving is good however it is too big for the screen it is cutting off on the peripheral. How can I reduce the size of the picture to fit on the screen?
    President:
  • 1,140 Answers
Hello Rascalise,
It's very difficult to give you the correct instructions without knowing the model number of your TV and whether you are also using a cable/satellite receiver or digital converter.
Assuming you know how to change the picture size (aspect ratio) of your TV, the correct setting will probably be called WIDE, FULL, or 16:9. Common buttons used on remote controls for changing the picture size are ZOOM, FORMAT, P.SIZE or ASPECT.
If you are using a cable/satellite receiver or digital converter and you cannot set the picture on the TV to the correct size, you may need to change the output picture size on this box. Many of these boxes use either the # or * (star) key for changing the picture size. Both are usually next to zero. On some boxes, this setting will need to be changed using the on-screen menu.
Hopefully this information will help you to solve your problem. If you need further assistance, please let me know the model number of your TV and your cable/satellite receiver, if using one. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Mar 25, 2011
Zoom how do reduce picture size
usually tapping zoom again does it .
Dec 04, 2016 | Televison & Video
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
May 23, 2014 | RCA HD52W56 52" Rear Projection HDTV
Picture too large for screen
crop the picture edges using photoshop
Jun 17, 2010 | Insignia LCDTV26 26 in. Television
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Pictures are to big
You can use Microsoft Paint to reduce the physical size/crop your picture, or you can use a program called Winsoftmagic to reduce the physical size of JPEG pictures without cropping.
Mar 26, 2009 | Sony DSC-T70 Digital Camera
Picture too big
there will be a button on the remote that says aspect, or pic size, hit that button, untill you get the size you want, if you cant find the button, go into the menue, click the picture, or video section, and look for aspect racio, or pic size in there
Jan 09, 2009 | Polaroid FLM-4201 42 in. LCD Television
Picture too big
Normallly, if the picture size button on the remote for the television1.gif ( If it has a picture size or format button) does not achieve the desired affect, then, a cable box or a satelite box is where the change4.gif needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 27, 2008 | Televison & Video
Picture size
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Hope this helps.
Jan 05, 2008 | Toshiba 50H82 50" Rear Projection...
The picture is too big for my screen
press zoom on the remote control to get the normal size
Dec 24, 2007 | Toshiba 35A44 35" TV
Picture too large
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Hope this helps.
Oct 14, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
