Question about LG WM-2277HW Front Load Washer
Lg fabric softner dispenser does not drain is full of water
    Brigadier General:
  • 6,277 Answers
I suspect that the conditioner/softener tray needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
Good luck,
John C
Posted on Mar 25, 2011
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
Buffalo12980
  • 625 Answers
SOURCE: Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Posted on Sep 05, 2007
SOURCE: Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Posted on Jun 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Water is backing up in the fabric softner
The problem is due to conditioner compartment being blocked, do the following.
Remove and thoroughly clean the soap drawer, and all individual parts of it.
Get a fairly stiff piece of wire, make a right angled bend in it about 1" long.
Poke it into all the holes in the top of the soap drawer compartment, particularly the ones at the top right of compartment.
This should solve the problem.
Posted on Dec 03, 2009
SOURCE: Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Posted on Dec 17, 2009
Fabric Softner
that is normal you can either add water to make it drain or pull out the drawer and dump it.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sep 09, 2009 | LG Washing Machines
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Sep 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
LG WM-2277HW Front Load Washer Logo
585 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
