Question about Health & Beauty
Chair was working. replaced batteries. now not working . all lights now flashing. tried moving freewheeling levers but no help
  • 692 Answers
Might be sleep mode try pushing the on/off button twice to get out of sleep mode Hope this helps
Posted on Mar 29, 2011
I bought used mprv 4 hooveround, been setting for a couple years and I put new battries in it,I put it in driveand all the lights come on you can near something running when you move the lever forward,...
take the freewheel levers and move them up and down a few times then leave them both in the up position. Turn on the chair and see if it works correctly The noise you hear are the motors or motor running because one or both levers are in freewheel.The clicking you hear is the electric brakes engaging when you move the joystick Hope this helps
May 06, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
I had explainted that my Pride Jazzy wont move. The battery light just rolls from lft to rt. The yellow light at bottom flashes 5 times. When we plug it in it appears to be charging again. please help....
Check the freewheel lever at the side of the chair behind the wheels to make sure one isn't in freewheel mode both levers should be up all the way towards the seat. If the levers are up all the way and you are still getting the error then you have a right motor wiring problem and you can't fix this problem yourself. If Medicare paid for your chair then they will pay for most of the repair cost contact your provider or Roadrunner Mobility @ 1-800-467-2668 Hope this helps
Apr 16, 2011 | Health & Beauty
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
Joystick lights all flash,new batteries,doesn't move.
The number of lights that are flashing can indicate what the problem is. Make sure that all of the battery connections are tight and the fuses are good. Try to reset any circuits like the freewheel/brake lever. You can also visit this site for help:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the type of controller on your power chair to see what the flashing lights are trying to tell you.
Oct 16, 2010 | Electric Health & Beauty
Controller light is flashing and chair will not move
Sandi Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. This will give you the flash error code and your users manual should tell you what the number of flashes indicate. (for example 3 flashes bad brake) Also check to make sure your scooter is not in freewheel. Turn off the scooter and move the freewheel lever in and out of gear a few times then turn the scooter on and see if you still get the flashes. If you can't figure out what is wrong then contact your provider and ask if they can check it out for you. Hope this Helps
Oct 03, 2010 | Pride Go Chair Travel Power Chair
Lights blinking when power is turned on chair will not move
RB Are the lights giving you a flash code ie: 4 flashes pause four flashes etc or are they all flashing with no pattern? Make sure the chairs freewheel levers are in the drive position then turn it back on to see if they still flash. If the lights are scrolling from right to left then the joystick is in lockout mode. let me know what you find and maybe we can figure this out. Hope this helps you
Sep 11, 2010 | Jet 3 Ultra Power Chair
I have an Aspire 18 04, model K0011. The batterey indicator lights show fully charged but when you turn the chair on all the lights fliker real fast and there is no response or sound being made when you...
Dave did you check to make sure you are not in freewheel. If you can push the chair easily then you are. Even having one side in freewheel will cause the flashes. Move the levers to drive mode that are on the back of the motors then turn the chair on and see if it works Hope this helps Also make sure the charger is still not plugged in.
Sep 08, 2010 | Health & Beauty
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
Lights flashing
If your chair is in freewheel (levers on back of motors not in drive) then the light will flash. But are the lights scrolling left to right or right to left? You can check for freewheeling by trying to push the chair from behind if it moves easily then it is in freewheel and you will have to move the levers to the drive position. You need to give more info of the flashing lights are all the lights flashing are only some flashing? etc
Aug 16, 2010 | Invacare Supply Group Invacare Pronto M91...
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
Health & Beauty Logo
54 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
