Question about Lasko 3300 Wind Machine Fan
Show pictureshow to take fan apart to clean - Lasko 3300 Wind Machine Fan
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Have several small DT-70 table fans. Wondering is it possible to take them apart for cleaning? I have NO idea where my manuals are, bought them several years ago. If they cannot come apart for cleaning,...
There are 6 screws, deeply recessed, in the rear of the fan case. (At least that is how they are on mine, phillips or cross head)
Once they are loosened, the front and back will come apart. I Do that annually so it can be thoroughly cleaned..
Otherwise, I use a toothbrush to fit between the slots to get most of the dust, also a paintbursh with stiff bristles for the outside grills.. Similar small brushes should work for loose dust. Also can blow out loose dust with a shop vac with blower capability.
Jul 21, 2010 | Dryers
My sony wega's picture goes on and off, but doesn't power down. it's not as if the lamp stops, but only shows blackness.
It is the lamp cycling imagine its like a street lamp, it turns on gets to temp then powers down because of too much draw.
I suggest new bulb and take apart set to clean all cooling fans and take apart projector assembly as cooling fans in there become clogged with dust.
Apr 18, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I'm having overheating trouble with my Gateway 7322gz. I'm looking for a repair manual to show me the best way to take it apart so I can clean it and replace the fans if needed
You don't necessarily have to take it apart. Simply taking a vacuum, and putting it close to the fans, while sealing one of them with tape works well enough. I tried this on an old HP and it works well enough. Compressed air is also OK.
Aug 26, 2009 | Gateway 7322GZ Notebook
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Ulead CD & DVD PictureShow 4
conflict between program and AV. Only way would to be disable AV when you want to run ULead but then you are exposing yourself to threat. Will AV allow you to add the executable as a safe source?
Oct 21, 2017 | Ulead CD & DVD PictureShow 3 Deluxe for PC
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Jul 03, 2008 | Marvin 1210 Floor / Box Fan
Lasko 3300 Wind Machine Fan Logo
151 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
