Question about Dymo ExecuLabel LM450 Thermal Label Printer
My Dymo LabelManager 450D jams up at the point of the cutting blade. It printers the label, but never makes it out of the machine. It's fairly new, but has exhibited this type of problem all along. You actually ruin your cassette trying to take it out and unjam the tape cassette.
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Posted on Apr 29, 2009
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
  • 126 Answers
SOURCE: Dymo LabelManager 300
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
Posted on Jul 15, 2009
ejkudelka
  • 1188 Answers
SOURCE: Where can I get an Operating Manual for my Dymo LabelManager 350
Here is a link to the manual:
http://global.dymo.com/img/compel/Q5S_A-MZSgeJZGJ73tJmbPunig_yx_v1.pdf
You will need Adobe Reader installed to view the PDF, try to open it, if it doesn't work, go to adobe.com and download the free Adobe Reader. If you don't want to do that and cannot open the link above, here is one that doesn't need Adobe, but it isn't formatted as nicely:
Unformatted Non-PDF Manual for LM350 - Click HERE
Posted on Dec 15, 2009
  • 7 Answers
SOURCE: I took out the tape D1 label cassette for the DYMO
I know this is too late for the psalter29, but here it is for others with the question. This piece is a cleaning tool. It is stored in the lid to the tape door. There is a small bar in the lid. The slot on the tool slides over the bar in the lid. The soft yellow pad should push down on the tape when the lid is closed. It is a cleaning tool for the print head. The user guide says "gently wipe the pad across the print head". The device should still work without the tool.
Posted on Dec 23, 2009
How do I change the font size on a Dymo LabelManager 350?
Please follow this instructions
Changing the Font
Six font are available for your labels:
Arial Narrow, Arial Normal, Arial Wide, Times
New Roman, One Stroke and Frankfurter.
When you specify a font size, that size applies
to all characters on current page.
To set the font
1. Press the Font key.
2. Use the arrow keys to move to the desired
font and then press OK.
Also here the link to the manual for further instructions.
regards
Mar 25, 2011 | Dymo LabelMANAGER 350 Thermal Printer
My dymo labelmanager 9000 will not print labels, a comment comes up saying label with arrows pointing to the left each time i press the print button. i have tried pressing the bottom feed button...
The fix for this involves opening the unit up. The problem is the infra red LED sensor on the label exit has slightly miss-aligned giving the error. If you unscrew the two sensor boards, re-align and screw them back all will be well.
Hope this helps.
Jan 10, 2011 | Dymo LabelMANAGER 9000 Printer
Hi our LBELMANAGER 350D KNIFE KEEPS STAYING OUT
have the same on labelmanager 450. See if you can see any tape/glue particles on either side of cutting edge .
I cleaned the cutting edge with a thoothpick by pushing the point on the cutting edge and cleaving the wood, then moving ther thoothpick up/down along the cutting edge. Usng any metal tools may damage the knife.
Roger(Belgium)
Nov 07, 2009 | Dymo LabelMANAGER 350 Thermal Printer
How do I reset my Dymo lablel maker I have ! ! ! ! ! ! when in use
!!!!!! is a (rather unhelpful) error code that means basically that it can't print for some unknown reason. If the tape is not jammed in the printhead, and the tape seems to move freely, then generally it means the machine is broken.
To be sure you can call Dymo tech support on 020 7341 55 29 (UK)
If it's under warranty, you can return by going here:
http://global.dymo.com/enGB/ServiceAfterSales/default.html (UK)
If not you'll need another one...
http://www.dymo-label-printers.co.uk/Dymo-Label-Maker.html (UK)
You don't say which model you have, but if it's the one in the picture it should still be under warranty as they're fairly new and come with a 3 year warranty (in the UK at least).
For US or other countries go to www.dymo.com and select your country, and then the returns and contact information can be found there.
Nov 04, 2009 | Esselte Dymo LabelManager 120P Compact...
Jul 15, 2009 | Dymo LabelManager 300 Desktop Labelmaker...
Dymo ExecuLabel LM450 Thermal Label Printer Logo
350 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
GuruGrundy
GuruGrundy
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
