Question about New World 50GSO Gas Kitchen Range
I have just moved into a house with a new world twinline 3000. Grill works fine. Nothing happens when I switch on the oven, no gas sound, no sparking. I've tried moving the knob to 8 & holding it in, still nothing. The timer is working, but I can't work out how to set the time. There is a little A flashing. The house has been empty for 6 months & I don't know if it was working before.
5 Suggested Answers
Mikey1963
  • 27 Answers
SOURCE: Grill wil not work
The termocouple is broken, just had the same problem myself, looking for replacement part will let you know when I find the part.
Posted on May 27, 2008
SOURCE: New World Twinline 3001
Brute force and total ignorance seemed to work!!
Posted on Jul 15, 2008
SOURCE: Oven stopped working
replase the oven ignitor it's located nest to the oven burner.
Posted on Dec 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
New World(Stoves) Twinline Gas Oven About 9-10 yrs old
The control board should probably be replaced
Apr 01, 2008 | Ovens
Oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Jan 06, 2010 | Ovens
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
Jul 14, 2008 | New World 55WLg Gas Kitchen Range
Grill wil not work
May 25, 2008 | New World 50GSO Gas Kitchen Range
New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Apr 27, 2008 | New World E70DOa Electric Double Oven
Oct 22, 2007 | New World 60ESO Electric Kitchen Range
New World 50GSO Gas Kitchen Range Logo
94 people viewed this question
Top New World Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
John Rodgers
John Rodgers
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
