Question about Dell 1815dn All-In-One Laser Printer
Dell 1815dn when scaning a document the document has blank wide line down it.
I CAN DO NOT SCANNING MY DOCUMENT??
Posted on Mar 29, 2011
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
I uploaded the driver software on my computer but it did nothing when i hit the test print button. when i go to print a document i have to select the printer. but it only comes up as a dell 1815dn fax. no...
Your software driver installed incomplete, need to reinstall again.disconnect first the USB printer cable, then install the software driver if installation instruction on screen connect your USB cable follow the instruction.
If same problem, try to download printer software driver to this link http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_1815DN&os=WLH&osl=en&catid=&impid=
then select your present operating system to get software driver compatible.
Hope can help to you.
Regards
Jul 15, 2011 | Dell 1815dn All-In-One Laser Printer
My dell Laser Multi-Function Printer 1815dn has a line going straight down on any paper printed through the feeder
If it is from the ADF (Automatic Document Feeder ), it probably is a speck on the scanner glass. Lift up the top scanner cover and clean the glass esp. the narrow glass on the left side. Also, lift the small ADF cover and clean the rollers with a lint free cloth dampened with a mixture of alcohol and water.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 16, 2011 | Dell 1815dn All-In-One Laser Printer
The paper will not feed to fax or copy on the top loader.
If your Dell 1815DN is jamming at Document Feeder (ADF assembly) the display may read Document Jam. You should replace the ADF Seperation Pad (Part# D1815-Z3) and the ADF Pickup Assembly (Part# D1815-Z4). Here is a video that shows you how. Iteminc.com has these parts and ships same day.
Jun 20, 2010 | Dell 1815dn All-In-One Laser Printer
How do you scan a paper to a PDF file on dell
Scansoft (or Nuance) PDF Converter 3 is a useful utility for converting documents to PDF files
Mar 02, 2010 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
Feb 06, 2010 | Dell 1815dn All-In-One Laser Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
1815dn blue line
Check for damage, residue, or excess toner on your imaging drum, transfer belt, or transfer roller.
May 05, 2009 | Dell 1815dn All-In-One Laser Printer
Lines going thru the pages of fax i send
you ma try to make a copy see if have lines through the page if does, you may go to document feed unit open the cover you may see a piece glass just use alcohol to clean it should take care your problem
Dec 13, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
57 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
