Question about Frigidaire ATF6000ES Front Load Washer
It wont spin or release the water - Frigidaire ATF6000ES Front Load Washer
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Hi my simpson esprit 550 has suddenly stopped spinning,does everything else fine,any suggestions wod b much appreciated,thanku
Has it pumped out? It wont spin if still full of water. Check for blockages etc in hoses and the pump. If its pumping out, there could be a problem with the brake release or it may be the lid switch. It wont spin if the machine thinks the lid is open. Older 550,s had a switch that was operated by a lug that stuck out of the back of the lid, newer ones have a magnetic switch under the top of the machine.
May 19, 2015 | Simpson Washing Machines
My estate washer will not spin the water out, it spins & agitat's but wont release the water
Check the lint trap at the base of the machine, it should be behind the front base panel
Jul 30, 2014 | Estate Washing Machines
Wont empty or spin and wont release door
Hi cacaedwards,
The reason why it is not spinning, is because it can not drain the water already in the machine, and the door is not releasing for the same reason.
I would advise you to first lay the drain hose on the floor out the door (into a drain preferably) Most water will start to siphon out at this point.
Then,
You may need to clean the drain filter on your machine, find instructions on how to do it, by reading this following tip:
ACCESSING AND CLEANING THE DRAIN FILTER
Kind Regards :-)
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 12, 2011 | Washing Machines
Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Dec 30, 2009 | Washing Machines
My hotpoint washer dryer wont spin. it is making a hunnimg noise when i try to make it spin.. also i turned it off and the door released so i could take my clothes out okay but they were soaking wet! i...
It sounds like you have a problem with your spin/agitate motor or gear assembly. The drain is open it works by water pump and by centrifical motion. Opening thr drain duct shouldn't help anything. It really needs to go in to spin cycle to drain water. As far as it not spinning, you can buy replacemnet parts for the spin/agitate motor and gear drive, or belt drive if it is belt driven..
Aug 07, 2009 | Washing Machines
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Water wont drain /wont spin out
  • assuming it is a top loader
  • it sounds like something is stuck in the water pump.
  •  if the water does not drain then it will never spin.
  •  take off the front panel (with a butter knife, push in the two metal clips in the front seam between the top panel and the front panel. this will release the front panel from the machine.
  • the water pump is located on the right side in the front.
  • before removing the hoses attached to the water pump get as much water out of the machine as possible so it does not spill on the floor.
  •  then take off the hoses and check inside the pump thoroughly; even a string might cause the pump to get stuck.
  • let me know if you need more help
Mike
Jul 02, 2008 | GE Washing Machines
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
14 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
