Question about Gigabyte GA-8TRS350MT Motherboard
I have a problem with my Gigabyte GA-8TRS350MT motherboard. I started my PC up, but the monitor didn't switch on. Later that day, I tried again, and it worked! Then after about 1-2 hours, it switched off again. It justs happens randomly. I tried another CPU, and the same happens (It just doesn't want to start up, and when it does it shuts down after a few hours) My fans, HDDs and other components all work 100%. The monitor works fine with other PCs, and I tested the components with other PCs too, AND THEY ALL F****NG WORK! Please help!
  • Phil Mar 25, 2011
    Are you doing any overclocking on this board?
    Problem Solver:
Are you using on board video. If so, try using a video card . If the video card don't work, more than likely out of my experience the motherboard is shot.
Posted on Mar 25, 2011
    Genius:
  • 1,126 Answers
It sounds like a power supply problem not the mother board, you have some bad electrolytic caps in the power supply that need to be change, or just replace the power supply.
Gigabyte GA-965GM-S2 motherboard keyboard, mouse, monitor won't work.
You need all the drivers, each peripheral has it's own driver that needs to be loaded.
Nov 28, 2011 | Gigabyte GA-965GM-S2 Motherboard
Ga-8trs350mt display driver
You may want to producer website and download drivers for your motherboard from this link
http://it.gigabyte.com/products/page/mb/ga-8trs350mt/download/
Mar 01, 2011 | Gigabyte GA-8TRS350MT Motherboard
I switch on my system and nothing happens The cpu
So practically the pc starts but you don't have any image. Try using another monitor and another video card - one of them is dead.
Jul 03, 2010 | Gigabyte GA-8I915P Duo Pro Motherboard
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
NOOO
Hello there
Plese explain what NOOO means.
I cant help you if you will not explain what is going on or what happned or what is happening. ok ??
best regards michael
Aug 27, 2009 | Gigabyte GA-8TRS350MT Motherboard
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Sparadic power interruptions
try checking the cpu fan and heatsink for dust build up
Dec 31, 2008 | Gigabyte GA-8ST800 Motherboard
Not booting
Check your monitor,if it is running fine.Switch off your pc and monitor both.Switch on again.If u are not getting any display on screen ,u may need to repair your monitor.in between press on capslock or numsluck key.If keys are giving lights then 100% it is a monitor problem.
Jul 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Pc sometimes cannot find ide devices
You can try wiping the cmos settings, as they may be corrupt, find the JBAT1 terminal on your mobo and put jumper across pins 2-3 then back to pins 1-2. Boot up pc and reset time, date and get the bios to auto identify drives, normally F12 depending on mobo. Also check that your cmos battery isn't low as it may keep losing the settings.
Mar 12, 2007 | Gigabyte GA-8S655FX-L Motherboard
Gigabyte GA-8TRS350MT Motherboard Logo
87 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
