Question about Acer TravelMate 2300 Notebook
MY LAPTOP DO NOT TURN ON AFTER BUILDING HARD DISK
I HAVE FORMATED MY ACER 2300 AND REBUILDING THE HARD WARE BUT AFTER REBOOT HE DIDNT TURN ON WHAT's the right solution for this kind of problem?THNKS
  • 34 Answers
Sorry I need a little more information before I can solve your problem. What did you use to format your hard drive? What does the computer do when you press the power button? Do you hear any noise coming from the machine? Can you clarify what you mean by "rebuilding the hardware"?
Posted on Sep 11, 2008
System disabled 08579
I can't find any reference to this specifically. Try re booting and if there is still a problem, check the hard ware for any changes.
Jan 20, 2014 | Acer TravelMate 2300 Notebook
Need to restore to factory settings an dont have a reboot disk
Bro...no need to restore to factory..just format your hard disk and reinstall new windows
Nov 17, 2011 | Acer Aspire M1100-B1300A Refurbished AMD...
I have an acer travelmate 2300, i cant format it because the hard drive cannot detect by the computer, what is the probelm?
If the BIOS cannot detect the hard disk then it is most likely faulty.
To get your Acer operating again, replace the hard drive, install Windows on the new hard drive plus the Acer's device drivers and your programs.
You candownload the drivers from the Acer WEB site. Make sure you select the model of your laptop and the XP or Vista version of the drivers you that require and it matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Mar 03, 2011 | Acer TravelMate 2300 Notebook
I have an Acer Aspire x1700 and it will not reboot, I cannot locate the reboot disk. How can you help?
Yuo need a lot of try and error to be successful.
First your OS and the BOOT disk that comes with your machine.But if you dont had the CD you need to buy and download it.
Store like Bestbuy,CompUSA,etc.. sell this CD,s or go to this LINK where you can buy it online and download it, choose your OS and any other specs about your System.
After all you need to BURN the files in a blank CD or order for mail shipment.
Then we going to BOOT the system id the CD drive.
To rebuild your hard drive, do the following:
  1. Power up your Acer system.
  2. When prompted (after memory testing completes), press CTRL + ALT + ESC to enter CMOS setup.
  3. At the CMOS Setup screen select Advanced BIOS Features
  4. Verify the Boot Options Sequence is set to the following order:
    1st [CD-ROM]
    2nd [Floppy Disk]
    3rd [Hard Disk]
  5. Insert the Acer System CD, DISK 1 in your CD-ROM drive.
  6. Press F10 to exit and save. When prompted, Do you want to save CMOS data?, select [Yes], then press ENTER.
  7. The system will reboot from the CD-ROM. After booting from the CD-ROM, you will see the Acer Hard Drive Rebuild options displayed.
    Note: Use your mouse for choice selections during the HDD recovery process. The mouse will respond slowly during this procedure, DO NOT press the Enter key. Pressing the Enter key will cause the HDD recovery process to terminate.
  8. Select HDD Full Rebuild and follow the on-screen instructions.
  9. When prompted to insert Acer Recovery CD, DISK 2, wait for the CD-ROM to eject DISK 1.
  10. Close the CD-ROM tray and click OK. The system will continue to rebuild the hard drive back to factory load.
After being prompted to remove disk and restart system the unit will load system software and hardware. During this process the system will reboot several times.
Your Microsoft Certificate of Authenticity (COA) ID number will automatically be entered for you. Should you need this number for any reason, look for your Microsoft Certificate of Authenticity (COA) ID number on the cover of your system.
"thumbs and post back!"
Oct 24, 2010 | Computers & Internet
I have a acer 5100 aspire that won't recognize the hardrive half the time and won't find some of it's usb ports. I have reloaded windows and even tried different hard drives (used not new) and it seems to...
Do the following:
  1. Check in the BIOS to make sure that the HD is present in the system before proceeding..
  2. If not then power off the laptop and then carefully remove and replace the HD from and to its connector.
  3. Then secure it then reboot the laptop.
  4. Check the BIOS settings again to see if the HD is recognised.
  5. If you still can’t see the HD then obtain a USB to IDE / SATA adaptor cable from eBay or your local PC store and remove the HD from the laptop and lay it down on a flat horizontal surface and use the adapter to connect to the laptop’s HD and connect the USB to another PC. This will show if there are any issues with the HD itself and will allow you to format it if necessary.
  6. Then replace it back in the laptop and all should be well.
  7. If not then you can suspect that you have an HD controller issue which is a very costly repair in a laptop.
  1. If the laptop will boot or you have a bootable CD / DVD then change the boot sequence in BIOS to be CD/DVD then Hard Disk.
  2. Reboot the laptop.
  3. Once booted look at the Device Manager to see if there are any errors showing in the Storage Devices and the Hard Disk in particular.
  4. Then go to option 5 or use the bootable CD / DVD to reformat and rebuild the hard drive.
  5. If all the above fails then install a new Hard Drive, format it as required and reinstall the Operating System and applications.
Oct 23, 2009 | Acer Aspire 5100 Notebook
My laptop will not connect to windows, just keeps rebooting
If the laptop keeps on rebooting, the only problem is the hard drive (HD). You need to reformat the hard drive and reinstall the Windows. The reason why this is happening is because Windows is corrupted due to some reason (most likely due to virus).
Have a great day!
Oct 12, 2009 | Acer TravelMate 2300 Notebook
My Acer Travelmate 2310 freezes
Problem with the Hard Disk. either replace it or Format the Hard Disk to clear the bad sectors.
Jun 11, 2009 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
