The television on and display but after a seconds shut off....
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlight, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
Symphonic WF32L6 on power up power light flashes about twice per second for 20 seconds. Screen displays ''DIGITAL TELEVISION'' then power light flashes about 4 times per second for perhaps 10 seconds more,...
Ur Main Tuner signal board is dead.Replaced this board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Signal board for the replacement.
Mar 08, 2010 | Televison & Video
Nothing displays on screen
the bulb maybe burnt out, I had a similar problem only no audio. The odd thing was that the lamp light was not lit indicating the bulb was burnt.
Dec 01, 2008 | Sony KP-51HW40 51" Rear Projection...
My tv turns onn for a few seconds then shuts off
it can be repaired but it would be easier to buy a new tv and cheaper
Oct 22, 2008 | Samsung HCM422W 42" Rear Projection...
Monitor on switch goes onto green for 3 seconds and then turns to a flashing red, which flashes 5 times quickly,and repeats every few seconds. model is pioneer plasma display system noPDP503HDE
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Sep 19, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Tv shuts down in ten seconds
You gotta change the belt of the motor charge in the vcr thats all the problem.
May 06, 2008 | Symphonic SC1302 Combo
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
