Question about Jenn-Air Kitchen Ranges
The stove beeps and F1 appears on the display. Elements work and oven works. When we push cancel it still keeps beeping after a short pause.
  • 1 more comment
  • sherwood951 Mar 26, 2011
    I have no idea how to do this. Do I need to call in an electrician? Will I need parts? I live on a small island and parts are not obtainable here.
    Rick,
    I'll try to take the control off and see if I can tell where the trouble is. I would appreciate a copy of the schematic. It would give me some confidence as far as puttting the thing together again.
    I expect that your suggestion to replace both pieces is correct since we, here on Cortes Island, are quite far from any technician who could make a diagnosis.
    So, I await the schematic and any other instructions that you can offer.
    Alden Sherwood
  • sherwood951 Mar 27, 2011
    Rick, Thanks for all the help. We have decided to take the stove into an authorized repair person in Campbell River and see if they can fix it. I will let you know if they can fix it so that you will have that information for future reference So far, how much has this cost us?
    Alden Sherwood
  • 1,998 Answers
F1 indicates either a defective touch pad or defective electronic control also known as a defective clock in some terminology it gives this error code for f1 and what to do Replace touch pad or membrane (this problem is usually the touch pad) Replace touch pad or clock assembly (also called the ERC) if you have any futher questions message me back if you are able to you can check both these pieces and not always are both pieces at fault it is usually either one or the other observe the component board on each and visually inspect for burns or cracks in both boards or tears in the ribbon cable if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick p.s I await your reply
Posted on Mar 25, 2011
  • 3 more comments
  • Rick Ead
    Rick Ead Mar 26, 2011
    ok so if you live on a small island to order the parts you could go to www.marcone.com under contact us there is a 1800 number as well as an international number as well if you are not electroniclly inclined or have any worries due to this repair does deal with electricity you would call an appliance repair technician not an electrician if you are unable to do the repair the repair is pretty basic shut off the breaker to turn off the power going to your machine then you would disasseble the control so that you eventually had both the control and the touch pad removed i just had a thought this might work out to be cheaper on your end if you call the technician because he has to test between the two parts if one or both are bad watch out some just do the oh yeah both are bad without testing and just in parts that would run you over 250 not counting there labor bill where abouts are you anyway i Might be able to locate a reliable technician in your area I await your reply Thanks Rick
  • Rick Ead
    or you can send me the model number and i can find your schematic and then you can order the parts and try to replace both pieces together after considering you are on an island if you were to bring a appliance tech out there to test the unit to see which piece is bad you just spent just as much as buying both pieces so you might as well say heck with the appliance guy send me the model number and il try to give you some instruction on how to replace both pieces in my book cheaper is always better as long as the quality doesn't drop I await your reply and to see if you want me to look up the schematic for your machine Thanks Rick
  • Rick Ead
    i need the model number to get a schematic of your machine for your repair message me back when youhave this thxs Rick
  • Rick Ead
    Hello Alden,
    I still need you to give me the model number off the range in order for me to look up the schematic Thanks Rick
  • Rick Ead
    Rick Ead Mar 27, 2011
    please remember to rank how this opinion has helped it allows me to help others in similar situations and if you have any further questions message me back not sure on the cost The problem is the electronic control and the touch pad I await your reply Thanks Rick
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
My oven keeps displaying the symbol "F1" and continuing to auto-clean
Try pressing the stop/cancel button, if this does not work unplug stove and wait five minutes and then plug back in, this should clear the display
Nov 16, 2009 | Frigidaire FEF366EC 30" Freestanding...
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Jun 14, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
69 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
