Question about Shure SM58 Professional Microphone
My sm58 has a low level buzz or hum. how should I proceed to diagnose and repair. I am assuming a loose wire or a frayed wire grounding out.
  • Shure Master
  • 5,603 Answers
This could be any of several things. IF the audio output of the mic is at a normal level then the first thing to check is the mic cable. I have several things to discuss so read all of this and then test.
First, I found six BRAND NEW XLR cables were wired wrong... the vendor had 13000 of them in stock and was going to have to check them all. The cables appear to work, but had the shield and one signal wire in the wrong place so the line was NOT a twisted pair balanced as required, but instead a plain coax. I had to repair these at a venue when I discovered the problem. Please google the correct XLR configuration. The pin numbering is NOT what one would expect. You cables (open the ends and look) should have the shield tied to pin 1 which is one of the side pins. Mine they had the shield on the middle pin or apex of the triangle.
Second, there are COUNTERFEIT Shure SM58's being sold. Read about that at google... If you unscrew the screen and find a label on the side of the element, the mic is a fake... Now there are two qualities of fakes... some perform ABOUT as good as the genuine, and others don't even have the balancing transformer.
If the hum is only there while handling the mic, the ground to the shell is not connected... this is mainly a mechanical connection. You can extract the XLR male plug from the bottom of the mic by removing the side screw and gently pull out by grabbing one of the pins. Also you can verify the wire colors as the fakes use the wrong color wires.
Noise problems are my specialty so if you need further help send a comment to me.
Posted on Mar 25, 2011
  • bryan Dec 14, 2011
    i just got one from ebay. The sound is so low it's unreal. the crappy mics i have are louder. I did a few checks like u said and the wires are green and black? There is a label with caution on the neck on the mic when u take the top off. I guess i've been sold a fake? as far as im concerned as the sound is so low it's faulty in my eyes so will attempt to send it back. let's see what happens.
Why does trac off light keep coming on?
Probably a frayed ground wire, shared with other idiot lights (both check engine lights, brake system fault light, low oil level/pressure light) and the fuel pump. It is a multi-stranded wire that passes over the top of the transmission on the way back to the fuel pump mounted on the rear, center, of the fuel tank.. As the strands break due to flexing, various idiot lights intermittantly come on, until enough strands break to make them stay on, then finally stopping the fuel pump from pumping. Repair the frayed ground wire (most likely as it passes over the transmission), and everything goes back to normal.
Jun 30, 2014 | 2000 Chevrolet Cavalier
I have a brand new Sony Bravia flat screen HDTV hooked up to Charter Cable. There is a constant background humming sound which is really annoying. If I turn down the tv volume (to where I can't hear the...
Hey, first thing that comes to mind is that your cables are faulty.
OR
your receaver (or what your tv is connected to) Is causeing the buzz.
Possible reasons: the device has a bad connection or bad signal. Or your powersystem is unstable.
Heres a text about GroundLoop.
http://www.epanorama.net/documents/groundloop/
If you need more assistance let me know!
Mar 11, 2008 | Televison & Video
My AV receiver turns off a couple of seconds after I turn it on. I did what the manual said, unplugged the power source and removed all of the speakers but it continues to do the same thing. Anything else...
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate me"AS THUMBS UP" Thanks
  • Jun 20, 2011 | Onkyo TX-SR606 Receiver
    I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    My nad 3020 is making a buzzing noise when i connect to peakers even when nothing else is connected to it. any solutions ?
  • Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Jun 20, 2011 | NAD Audio Players & Recorders
    I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
    I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
    Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
    Mar 01, 2011 | Audio Players & Recorders
    Constant buzzing noise when using dvd player, playstation etc.
    If this "buzzing" sounds like a low frequency hum, then it is probably a loose or bad cable from the equipment. I am assuming you have this connected to an AV receiver or the tv. If the cables are not securely connected or is a damaged cable it causes the ground to be suceptible to "noise". That is what I would check first. Let me know if that fixes the problem, or what you did right before you noticed this issue.
    Aug 26, 2010 | Televison & Video
    Coolant level low light comes on and coolant level is not low in reserve tank or radiator.
    There is a TSB for this problem. Here it is.
    Bulletin No.: 04-06-02-007
    Date: August 11, 2004
    TECHNICAL
    Subject:
    Low Engine Coolant Level Indicator Always On (Diagnose Low Coolant Level System Operation/Check Sensor for Oil Contamination)
    Models:
    2000-2002 Buick Century, Regal
    2000-2001 Chevrolet Lumina
    2000-2002 Chevrolet Impala, Monte Carlo
    2000-2002 Pontiac Grand Prix
    2000-2002 Oldsmobile Intrigue
    Condition
    Some customers may comment that the low engine coolant level indicator is always illuminated.
    Cause
    The cause of this condition may be due to engine oil contaminating the coolant. Possible sources of oil contamination are internal engine leaks, improper service procedures, or the addition of some types of anti-leak additives to the cooling system. Once in the coolant, the oil leaves deposits on the level sensor creating an insulating film. This film results in a false activation of the coolant level indicator.
    Correction
    Diagnose low coolant level system operation and check the sensor for oil contamination using the procedure listed below.
    Important: No coolant supplements should be used in GM cooling systems, other than what is approved and recommended by GM. The use of "aftermarket" over-the-counter sealing and cooling supplements may affect the operation of the low coolant level sensor. Discoloration of the coolant recovery bottle is normal and does not necessarily indicate that coolant contamination is present. Flush cooling system only when instructed by this bulletin.
    1. Verify that the coolant is at proper level in the radiator and the coolant recovery bottle. If the coolant is low, add proper amount of 50/50 water and DEX-COOL(R) mixture. If the low coolant light operates properly, diagnose the cooling system for loss of coolant as outlined in SI. DO NOT proceed further with this bulletin.
    2. Remove the low coolant level sensor. Refer to Coolant Level Module Replacement in the Engine Cooling sub-section.
    3. With the key on, the engine off and the coolant level sensor disconnected from the vehicle wiring harness, observe the low coolant light:
    ^ Light is on - Chassis wiring or instrument cluster concern. Follow the appropriate diagnostic information in SI.
    ^ Light is out - Proceed to Step 4.
    4. With the key off, connect the coolant level sensor into the vehicle's wiring harness. Connect a ground wire (1) to the battery negative terminal. Using a sharp probe (3) attached to the ground wire, ground the coolant sensor probe (2) as shown in the illustration. Make sure a good contact is made. With the key on and the engine off, observe the low coolant light for at least 15 seconds.
    ^ Light is on - Replace the low coolant sensor and re-check system operation.
    ^ Light is out - Proceed to Step 5.
    5. Using a small wire brush or emery cloth, polish the low coolant level sensor probe to remove any film or oxidation. The probe should be a bright brass color when finished. Use Brake Parts Cleaner to flush removed deposits from the low coolant sensor probe. Re-install the low coolant sensor into the vehicle and proceed to Step 6.
    6. Flush the cooling system and install new DEX-COOL(R) mixture as outlined in the SI. Check the vehicle's warranty history to determine if any engine gasket had recently been changed. If there has not been a recent gasket replacement, locate and repair the source of the engine oil contamination.
    Oct 31, 2009 | 2002 Chevrolet Monte Carlo
    LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
    have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
    Aug 19, 2009 | Vizio L37 Television
    Buzz....hum problem from turntable....
    Did you ground the turntable? Most of them have a ground wire located somewhere that connects to a screw on your electrical outlet. You could be getting hum from your pre-amp if it is a low quality one. Try unhooking the pre-amp, if that is the problem you won't hear the hum. If the turntable ground is the problem you won't hear music with no pre-amp but you will still hear the hum.
    Jan 11, 2009 | Technics SL-BD20D Turntable
    Shure SM58 Professional Microphone Logo
    894 people viewed this question
    Top Shure Audio Players & Recorders Experts
    Michial Gueffroy
    Ben Armstrong
    Jerry Greenberg
    Jerry Greenberg
    Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
