Question about Cameras
I have a canon digital camera and its not old. One day for no reason it stopped working. i didnt drop it or anything. i know its not the battery because I switched the batteries with another camera my mom has and it works. I don't want to buy another one because I spent alot of money on the one I have.
    Master:
    Sergeant:
  • 398 Answers
Contact Canon and check on warranty.
Posted on Aug 03, 2008
Canon digital ixus 750... problems with flash
Your flash or mainboard are bad, only way to know which is to replace one and see if it starts working.
If you can't find a suitable parts donor camera online please let us know, we can get boards for only about $45.
Thomas D
Owner; Darntoothysam com
Oct 02, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Colorful streaks/spots on my camera screen.
probably a bad connection to the lcd display. warranty fix.
Jun 19, 2009 | Canon PowerShot SD1100 IS Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera wont turn on
Very odd that both cameras would stop working at the same time, has someone else abused them?
Removeing the batterys for a while is a good enought reset, check the battery connectors and contact your dealer if they both have warranty you will get them repaired or replaced for free. other than that I can recommend you a repair man if you provide me the city you live in.
Jun 12, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Canon SD 850 says lens error,
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Jun 09, 2008 | Canon PowerShot SD850 IS Digital Camera
Camera wont turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 27, 2008 | Canon PowerShot S45 Digital Camera
Canon Powershot s70 not working at all! :(
I've had the same problem...after 3 years of fantastic operations, it just died after a few shots on day...just can get it to power up...not sure if its worth a repair as you can buy a 7.1 MP camera these days for ~$200...and they're smaller... but Im sad coz I really did dig my S70....
anyone can help us?
Aug 20, 2007 | Canon PowerShot S70 Digital Camera
Camera goes on but lens and zoom do not work
I saw a post suggesting removal of batteries for 24 hours to reset camera, then try brand new manufacturer recommended batteries.... (my wife informed me that my 3 year old dropped ours....... i know there is a moral to this story.... but try the 24 hour approach to see if it resets... otherwise probably not worth fixing...good luck
Jun 13, 2006 | Canon PowerShot A510 Digital Camera
Dead Canon A75
A complete camera failure is usually caused by a power problem. Naturally, after checking the batteries, you should inspect the metal battery terminals inside the battery compartment. Also, many cameras (including the Canon A-series) have a memory card door with a safety interlock lever (power switch) that is engaged only when the door is completely closed. Finally, I have learned (from a Canon camera forum at Digital Camera Resource) that there is a small fuse soldered to an internal circuit board that sometimes fails for no apparent reason with several different "A" series Canon digital cameras. The fuse story, with photos for those brave enough to void their warranty and open up the camera, begins inside this thread, "Canon powershot A85 spare part needed!!!" at this web link: http://www.dcresource.com/forums/showthread.php?t=18151 You'll need to read a couple pages down to get the entire story. Good luck.
Jun 08, 2006 | Canon PowerShot A75 Digital Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
