Question about Twinhead N14RATK Notebook
W34oua gateway system restore download
Computer is installed with xp it lets me get to xp main page then nothing just my background ,also computer constantly hot from start dont have system restore cd for computer please help
    Guru:
  • 341 Answers
You need to solve the overheating problem first. Shut down the computer, unplug it and remove the bottom cover. Clean the dust and lint. Blow compressed air from a compressed air can. Re-install the cover and restart your computer. If you own a laptop, the fan should be running ALL THE TIME, sometimes slow, sometimes fast buta always running. Check the the fan is blowing air. If it is not, you'll need to replace it before doing anything else.
Posted on Mar 20, 2010
Gateway login
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both.
Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page.
Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make.
Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 18, 2013 | Computers & Internet
Gateway keyboard shortcut keys not working
You have two options to fix them res problem:
1. Do a system restore by clicking on start > programs > system tools > system restore. Select the date when everything was working fine and finish the restoration process. Let it restart and check if everything's working fine.
2. Update the driver of your computer. The possible problem of your computer are the outdated drivers. Doing updates manually is such a headache specially if you are not that computer savvy. If you want to do it automatically, then you can install RadarSync in your computer.
I hope this helps!
Carlo
Jan 22, 2013 | Gateway Computers & Internet
I can't get my laptop to boot up.
It sounds like your Explorer.exe is corrupted or missing. when you see your desktop wallpaper then you can try to open task manager my pressing Ctrl+Altr+Delete keys all at a time and now click "new task" and type Explorer.exe and press enter. if your Explorer is OK then your icon and other thing should land up if not then restart computer and try to open computer in safe mood by pressing F8, if you can open then try restoring your computer to earlier date by going to start----program---accessories----system tools -----system restore.
Aug 21, 2012 | Gateway MX6447 Notebook
My gateway gt5228 media center series is unresponsive. it will not let me intiate system restore, it will not let me start ini safe mode, i cant run the restore disc, and it will not let me restore it...
If you're lucky, the only issue is a failed hard drive. Install a new drive then use another computer to download the correct Operating system image and burn it to either disk or usb.
Software Download
Oct 25, 2017 | Gateway GT5228 (7156) PC Desktop
I cant print anything from my computor, as i have deleated the software for the printer, now i cant re install as i have seem to misplaced my cd for the installation..
You can restore your system by following this steps:
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as an administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  3. On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete page.
If you successfully restored your computer to a previous state, and the computer performs as expected, you are finished.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Office Equipment & Supplies
Virus says open with
If you have an Antivirus program on your computer, try getting it to scan and quarantine the virus first. If that doesn't work, and you're running XP or higher windows, restore your computer to an earlier date than the problem started occurring. I've had success with this method. Go to "Help and Support" and go to "Backup and Restore", then "Restore". Pick a date and then let the machine run- sometimes it takes it a couple minutes to run, then it will tell you to turn off the computer and let it restart. Good luck, hope this helps.
Apr 17, 2010 | Microsoft Windows XP Home Edition
I accidentely deleted my web camera and when i try to open it, it says that: This application has failed to start because Image.dll was not found. Re-installing the application may fix this problem. but i...
You need to tell me the Operating System?Is that an Inbuilt Camera, you are referring to?
Also, in the mean while try to below Trick :-
System Restore
If you are using XP,the procedure is :-
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Let me know with all details. Do Use System Restore before we look for the application.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 26, 2009 | Acer Aspire 3610 Notebook
System Restore disk
is there not a 2nd partition on your computer with the restore files on? If there is try pressing Alt + F10 when the gateway screen appears on boot. This will restore you computer to the factory settings.
Before restore starts it will ask you for a password, this would have been user generated when you first got the computer. If you don't know the password, press enter - maybe you didn't enter one to begin with and this will bypass it, or it may give you a hint as to what the password is. Or just try typing in admin. (if you don't remember your password - I don't know what to suggest, except it may be the same password you use for your user account or did use when you first got the computer.)
I have tried looking for restore disks for you and came back with nothing.
I hope this helps
Nov 14, 2008 | Gateway MT3705 Notebook
Computer model gatway w34oua
fix the overheating problem or the video will stop all together.
Aug 03, 2008 | Twinhead N14RATK Notebook
Computers & Internet Logo
430 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
