Question about Rheem EcoSense by 4.2 GPM Tankless Water Heater LP Gas
Our water gets cold half way through our shower. we have to go to the garage and shut it off and then turn it back on. This happens almost everytime we take a bath or shower.
1) You posted under Rheem tankless
Open following link for useful troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Unit can have internal part failure for example PC board, and result is that you get no error code.
This would explain why re-setting the tankless works.
3) Unit could also have loose wire or loose connection.
Or maybe the heat exchanger needs to be de-limed.
Or incoming gas, or incoming air, or vent problem.
Or water pressure, or water flow.
4) Without an error code, the problem can be household plumbing problem.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
5) Tankless repair is a large and developing field, and technicians train for years and still see new stuff each day.
Do-it-yourself tankless troubleshooting and repair might take equal amount of work.
First thing you want to do is read the manual several times.
Pay special attention to the word 'maintenance' and make sure you are properly maintaining water heater on yearly basis.
Next thing is to find qualified technician in your area, and put that person's number in your rolodex wallet. When technician comes over, ask that person for do-it-yourself tips and tricks.
6) Add a comment with your experience so other with same-similar problem can benefit.
7) Take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 25, 2011
Hi there, I have a bosch aquastar 125b waterless tank. My problem is that i am not getting hot water at all. The water runs during the shower and it stays warm. HELP!!
This should run two showers at once with no problem. If you have a shut off valve on the cold side of the heater, try closing about halfway. This will slow the water flow and the water will have more time to heat up as it pases through the tank. If you dont have a shut off valve, just cut back the hot water valve on your shower and do not use any cold water. If it gets too hot then turn on a little cold water. The object is to slow the speed of the water going through the tank. Tankless heater take a little getting use to but they work great when you know how to treat them. On my shower I turn the hot all the way on until it gets hot and then add a little cold water to bring the temp down. You may have too much water going through too fast to be able to heat it up to what you need. Try this and see how it works.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
Water tempeture gets hot then cool
Have you tried turning off the valves to the water heater and making sure you have no water flow out of the hot water tap? When this happens, often it is because of a problem with a shower cartridge allowing the cold water to cross over into the hot water side. It makes the unit think that the flow has reduced and the heater will turn down or shut off. Then things bounce back and forth Hot to Cold then back to Hot.
Mar 28, 2010 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Cold water suddenly shuts off during shower.
sounds like you may have "air" in the pipes and that bang has slamed the water reg valve shut hard
Mar 27, 2010 | Bosch AquaStar 2400ES-NG
Water heater shuts off when the cold water is turned on
Not sure but check the inlet water at the heater, the filter may be clog up a little that restrict the flow. Did u use the heater at all during the winter? If not, the heat exchanger may be clogged with built up in there. U need to descale it. Good luck. Chinhcu
Mar 31, 2017 | Bosch Water Heaters
Code 13 help... Everytime I go to use the shower (a mixing system of hot and cold) Code 13-- Code 12 the system shuts down. If I just use hot or cold I am fine-- Any one?
if cold supply to boiler and shower are off the same feed this could be your problem as the boiler governs flow of hot water best of luck
Oct 20, 2009 | Rheem EcoSense by 4.2 GPM Tankless Water...
Runs hot then cold
overheat stat call service engineer
Oct 09, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Rheem EcoSense by  4.2 GPM Tankless Water Heater LP Gas Logo
193 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
