Question about Acer ASPIRE 5536-5883 COMPATIBLE LAPTOP LCD SCREEN 15.6" WXGA HD GLOSSY LED (22099201502)
Acer aspire 5536-5883 powers up momentarily then turns off - wont post / boot.
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: acer aspire not booting up
Dear f1at3r1c
Righteo then, you should be starting by resetting your BIOS, and you can do this by removing the outer casing o the PC tower. Once yoiu have done this you then need to find the jumper that clears the CMOS/ BIOS. Now if you are somewhat unsure of what a jumper switch is, it just consists of a smallplatic cap which covers two metal conductive pins on the motherboard. There is usually a pin which is not covered.
Now once you have found the CMOS/ BIOS jumper setting, you will need to first remove the motherboard battery. The battery is nothing more than a glorified watch battery of the CR2032 type, and it will be silver in colour and obviously round in shape (typical cell battery).
Once you have removed the battery, you will need to then clear the CMOS/ BIOS and this is done by moving that jumper switch into the clear position. The pin that is exposed will need to be covered withthe plastic jumper, and the pin on the opposite side will need to be exposed. Leave the jumper in the clear position for about 10-20 seconds or so, and then replace it back to the original position. (doing this discharges all of the electricity in the BIOS/ CMOS chip). Once you have done this, you put the battery back in place and then start the machine, then you are good to go. Start the machine and enter the BIOS as you planned to do. You might want to consider ormatting your hard disk and re-installing windows or whatever operating system you have, and this is eeasy enough, just change the boot sequence to boot from your CD/ DVD drive first, the your hard drive second. Once its loaded up, re-enter the BIOS and reset it back to HDD first.
Now f this has not worked, then you have an oooopsie (this is my saying of oh ***T, oops, something has malfunctioned. Its more than likely to be hardware driven, so take out your hard drive first and try to boot, if it lets you bios, then you found your fault. Try this with all devices until you either find the fault, or you have narrowed this to your processor/ motherboard.
Now im sure this will solve your problem, but there is one thng you should need to know about, and it is how to identify the correct jumper. This will have either any of the following markings written on the motherboard very close to the where the jumper is. You may need glasses/ magnifyer lens in order to read the lettering, but it should say one of the following things.
CLRCMOS
CLCMOS
CLRBIOS
CMOSRST
RESET
CMOSRT
BIOSRST
CMOSCLR
CLEAR
could also be under J1, JUMPER1
Now im sure that this is the fixya for you, but if this still does not work, then please get hold of me, and i will provide you with more info.
I wish you all the best, and hope you manage to solve this issue sortly
kind regards
yours sincerely
Oz
Posted on May 11, 2008
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
  • 341 Answers
SOURCE: My Acer Aspire 5520 blinks the power light when I
It looks like your battery is either discharged or has a short circuit.
Plug the power AC cord in the laptop and let recharge the battery at least 3 hours before you try to start it again. If the computer boots up, enter the BIOS and check to see if you have a "battery check" oprion. If you do, start it and let it run until it is done (it may take several hours to complete). It will check the battery charge cycle.
Posted on Mar 22, 2010
My acer aspire X1200 b601a wont boot past first POST screen, ive tried reseating the CMOS, but seems to have made it worse. it contains all original parts, though take into account that it was FACTORY...
IF the machine is just shutting down it's likely the power supply. If it's constantlly rebooting itself, it's a corrupt bootlog. If the machine is just "freezing" when it tries to boot, it's likely motherboard related.
Oct 09, 2011 | Acer Aspire X1200-B1601A PC Desktop
Acer aspire 5536 wont boot up
remove power cord, pull out battery, press and hold the power button for 10 full seconds. Wait 1 minute, place battery back in and then power cord. Then try it. This should work. If by chance it does not, check your memory chips because an effective one will prevent boot up. You can remove one at a time and try booting to see if one is faulty.
Aug 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire m3201 wont boot up
There are numerous issues that could cause this but if absolutely nothing happens, no lights, no fans, nothing then check the power supply. Use a simple voltage tester to see if you have any voltage on the connectors going to the hard drive and cd/dvd drives. If not this is a pretty easy and relatively inexpensive fix. You can e-mail me at globalmac@yahoo.com for more help.
Jan 02, 2010 | Acer Aspire M3201 Phenom X3 8650 PC...
Acer netbook wont turn on
You must be facing any of these four issues:
1) power issue
2) No POST
3) NO Boot
4) No video
Power issue - the system does not turn on at all. In this case check the AC adapter and the battery.
No POST - You may have to check the Memory, Hard drive and the optical drive. Can also be an issue with the video card2.gif/ key board/ mouse/main board which can prevent the system from turning on.
try reseating all the components above except the motherboard.
No Boot - Issue with the Operating system2.gif. Try booting into safe mode and check whether the system turns on perfectly. If so try to uninstall all the software you do not use. and may also consider a system restore2.gif. else consider a Dell Complete factory restore.
No video - Try flashing light on the screen and look for the desktop. If you see the icons then probably the back light needs to be changed else the issue is with the display itself or the video card.
Kindly comment.
Sep 16, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5570z wont boot to windows
Insert a windows boot disc. Go into the bios select it to boot from CD-ROM first. Then you can go from there. If you get it to boot to windows disc, then you could start reinstalling windows. If you are still having issues then there is a more serious issue. If you have any other questions let me know.
Thanks,
Lee
Aug 11, 2009 | Acer Aspire 5720-6661 Notebook PC
When i press the power button my acer aspire one.it wont boot
I recommend you try the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops.
Also check if there is a known issue with your laptop model since even others are experiencing similar issue.
Jun 25, 2009 | Acer Aspire One PC Notebook
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5315 refuses to boot up
plz try by reinstalling the operating system, if you cant then plz check your hard drive
Jan 13, 2009 | Acer Aspire 5315 Notebook
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
Acer ASPIRE 5536-5883 COMPATIBLE LAPTOP LCD SCREEN 15.6" WXGA HD GLOSSY LED (22099201502) Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
