Question about Garden
Tiller looses power when it gets hot/wont start when hot
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
My first hit is bad or weak spark.. as in a failing ignition coil or ignition module.. and/or spark plug.
It can be difficult to check spark quality on a hot engine.. The spark should be very blueish..if yellowish it's weak.
Check the plug and renew regap if needed.
If it still has compression when you try to start it.. it's probably one or both.
Always make sure you keep the cooling fins clean of debris..
Check the oil level.. obviously change if needed.. engines that are tuned properly.. have good spark air and fuel can still overheat if the oil is dirty and the shroud/fins are clogged preventing air to pass over the cooling fins.
Lastly would be fuel/air related. but it sounds like spark.
Best of luck
Posted on Mar 25, 2011
Tiller will not start changed plug and cleaned gas and lines
check for a stop switch or wire from the switch being shorted out
Apr 17, 2016 | Yard Machines Garden
Troy- bilt electric cultivatar tb154 wont start. Could it be the overload protection button?
it could be the overload protector or the electrical cord has broken inside so it isn't getting the power it needs or the brushes in the motor have gone out
Mar 28, 2013 | Troy Bilt Tiller/Edger 26cc, Model No....
Blades wont rotate
Check for a broken pin or loose grub screw in the drive area of the box.
Mar 11, 2013 | Troy Bilt Tiller/Edger 26cc, Model No....
I have a mantis 2 cycle tiller. it starts and runs for a minute then shuts off.
do a fuel system overhaul...but always w a 2 stroke pull the muffler and inspect the piston and cylinder if its not scored and you feel good compresion most likley its your fuel system. if it is scored it gets metal to metal and the hot metals expand.
Jun 22, 2010 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Tiller wont get fuel to start
Try disconnecting the line at the carb. Then carefully blow back to the tank. It may have something blocking the outet from the tank. If that doesn't do the trick, the float may be stuck and not allowing the needle to open for fuel to enter the carb bowl. Good luck...Lee
Aug 05, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Engine looses power, then speeds up, then looses power again
This sounds like the little fellow is getting hot. Are you using a good oil in the fuel don't skimp on that oil use the best you can find and get a new plug to sounds like the oil is killing your tiller.
Aug 02, 2009 | Mantis Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Motor overheats and seizes.
what is your proper mixture?50:1?
Be sure you are mixing 2cycle oil to 1 gallon of fuel or whatever it takes to make this ratio
My reccomendations are run 40;1 3.2 OZ OF OIL TO ONE GALLON OF GAS
also you may have a lean out condition and the H on the carb, may need to be ritchened a little
Motor should not be screaming you should have a slight blubber when throttle is held wide open
May 25, 2009 | Mantis 2-Cycle Tiller
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
