Question about HP Officejet 6500 AllInOne InkJet Printer
After copying, the copy did not come out normally, it came out only halfway and crumpled so I helped by pulling the crumpled paper BUT a corner of the paper is stocked in the printer. The message on the control panel says: General Printer Error C0-6100000e.
  • 255 Answers
This is a carriage jam error.For further help refer tohttp://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Contact HP customer care for immediate help.
Posted on Mar 25, 2011
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Sounds like there is a papper jam but I can not see papper. Copies are coming out crumpled.
These machines use a fuser film. When they get torn or go bad they make a paper crumpling sound. When this happens it also causes wrinkles and creases in your copies. There may also be areas of your copy where the print will rub off. This means it is time for a new fusing unit. They are not cheap and removal of the old unit and installation of the new unit is not easy so plan on having a service person replace it. Just do a search for Canon D860 fuser or fusing unit.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
Unable to get ESP3 to work after a paper jam. Cleared the guide at the back. Whats next?
Decided to press resume/copy and as the cartridge was cycling to the left pulled the plug. The cartridge was now stuck on the left and the right section of the printer was now accessable. Removed a piece of paper that got crumpled in and the problem was resolved on re start.
Jun 06, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper get jammed in the automatic feeder on top of my printer
3 possibilities.
1 If you use this macine to copy labels, there may well be a small piece of a label stuck in the paper path on the crumpled side. Or a small bit of paper.
2, the paper pickup on the crumpled side is 'polished', and no longer feeding the paper at the same time as the uncrumpled side. They can be cleaned with rubbing alcohol. Though that is a temporary fix and the paper pickups should be replaced if cleaning fixes the issue.
3 The fuser film has a tear in it on the crumpled side you need to rule out 1 & 2 before going to three again replaceable but a bit more difficult
May 20, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Crooked Cpoies
Pull all of the paper out of paper tray and reload. More than likely you will find some sheets on the bottom that are folded at the corners. This will cause crooked copies and also jams.
Jan 14, 2009 | Office Equipment & Supplies
Copy machine problem
hello, sir
i have a photo copy machine of canon ir2018N.
my problem is when i start my photo copy machine his inistailzation process start and then given to messeage System ERROR E261 is show.plz sir slove this problem very urgent.thanks
Nov 24, 2008 | Office Equipment & Supplies
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
PAPER FEED
the drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Sep 17, 2007 | Canon FAXPHONE L80 Laser
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
HP Officejet 6500 AllInOne InkJet Printer Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
