Question about B&K BK Mueller 122048RP Single Lev Kitchen Faucet
B&K #122048rp single handle sprayer nozzle. Problem--small stream of water through nozzle/sprayer. Seems to lose pressure at the mixer. Can you purchase,clean,or install a kit to repair the mixer?
How much should I thin paint for pneumatc sprayer?
you did not mention what paint, you did not mention what sprayer.
remember, if you use solvent - opacity of the paint is sacrified, tints are less visible, metallic require more clear coverage.
for water based paints - except airbrush, usually no thinning is required, but you need to first stir it well (at least 3min on manual or 1min 30sec if mechanical stirer is used) strain it, i am using old stockings for that purpose in single layer, works very well for me and if nozzle is above 1.4mm up to 2.8mm there is no problem whatsoever. if this is splatter paint (nozzle 4.5mm or greater) do not even think about thinning it...
for acrylic - if nozzle is between 0.8mm and 2.8mm, procedure as above and you need to add specific thinner, usually up to 20% albeit in some cases up to 40% per volume) so paint will be about like ight cooking oil - water.
for oil paints and enamels - solvent should be not more than 20%, albeit you can increase it up to 40% in rare circumstances, if you are using hvlp gun, you can, if you yousing hp gun - no! it will disperse too much.
for two packs and urethanes - not more than 20% better keep between 5% and 10%
for latex - in rare circumstances you are allowed to use very, VERY specific solvent, and ususally not more than 10%, nozzle usually is 8mm or greater in these paints.
Oct 19, 2014 | Air Tools & Compressors
Just installed a Jado Basil Single-Handle Pull-Down Sprayer Kitchen Faucet and the water flow is incredibly slow! Removed the check valve from the sprayer and it didn't help. Any other suggestions? Flow is...
The specs say that there are two check valves but the diagram does not show them. Take the weight off the hose and see if it is causing the restriction. If it is not, what is the water pressure in the house? The 2.2 GPM is the maximum flow rate.
Aug 25, 2013 | Jado 803800355 Basil Single-Handle...
How can i disassemble the sprayer handle on my kohler a112.18.1m kitchen faucet
1-800-4KOHLER
http://www.us.kohler.com/us/static/helpTopicsHelper.jsp?helpId=728
Aug 27, 2012 | Kohler Plumbing
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
Irregular water pressure from kitchen faucet, single handle pull out sprayer. What could be the cause and how do I fix it?
Do you have similar problems anywhere in your house,dose this occur when another water source is turned on,if not then a small pressure tank can be installed to regulate and stabilize the water flow at faucet,if you need further assistance re-post giving more detail about exactly what is accruing.
Jun 14, 2011 | Kohler Plumbing
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
Can you tell me how to pour water and chemical into the tank? the small nozzle for the gun is too small
The handle that you use to pump that sprayer will twist and come out... then you pour the water and chemical through that larger hole...replace the pump...twist it tight and then pump the pressure...
heatman101
Oct 27, 2010 | Rl Flowmaster FLOMASTER 1 GAL SPRAYER ()
The water pressure drops rapidly when the faucet is turned on. The pressure in the hose is constant, but when the sprayer is attached to the hose the pressure drops.
Seems like you have some debris in the sprayer. Remove the aerator and see if there is any there or take it outside and force water into the aerator and hopefully it blows out through the inlet.
Jan 29, 2010 | Blanco Classic Single Handle Faucet with...
B&K BK Mueller 122048RP Single Lev Kitchen Faucet Logo
Top B&K Plumbing Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
