Question about Gateway GP PC Desktop
Disk write error unable to write to disk drive C: data or files may be lost next msg I got a fatal exception 0d has occurred at ooc9:00000ff4. The current application will be terminated
  • Gateway Master
  • 11,800 Answers
The hard disk is dying - replace it and reinstall Windows by using the recovery cd that came with the pc when you bought it.
Posted on Apr 03, 2011
I have canofile version 2.5 >>>the files that have archived I can't retrieve. many times I lost a lot of files>>>what to do first to retieve these files second how to prevent it in the future plz reply to...
First determine if the hard drive where the archive is located is OK.
In My Computer or Computer (Windows 7) right click the disk drive select Properties / Tools / Check Now / click on both check disk options and click start. You may be asked if you want to run the disk check next time the computer is booted. Select yes.
Restart the computer and plan for the test to run over night.
If there are no fatal errors, suggest down loading a file recovery program such as Handy Recovery and see if it can find the lost files.
The secret, if there are files that we don't want to ever lose is to back them up regularly to an external drive or CD/DVD.
Oct 29, 2013 | Canon Canofile For Windows Full Version...
Status 0x00000e9
Many of the problems caused by programs lead to the emergence of the messages that come in shape
A fatal exception XX has occurred at XX.
Often occur, because the program on the problem of improper code required Processor Processor you make improper operation. Thus Windows displays this message to tell you so and ask you to tell him what it must do. In fact, these kinds of errors do not escape them and often lead to the closure of the program or you may have to restart the Windows operating system as a whole and therefore you will lose any unsaved data before, and you models for these errors.
He noted that in all the solutions that Snordha here we'll use the letter A to represent the floppy drive and the letter C to represent the hard drive that contains the Windows system device and the letter D to represent the CD-ROM drive, and that all the messages and solutions applicable to Windows XP and Windows Me unless stated one only.
Message:
A fatal exception 00 has occurred at XX
Meaning:
This error occurred because the processor tried dividing the number to zero which is the correct thing is sporty and therefore this letter appeared.
Solution:
Close the message and try to continue to use the program, if you can not close the program and then restart it again, or restart your computer if necessary College.
Message:
A fatal exception 0C has occurred at XX
Meaning:
This error occurred because one of the instructions stored within a certain part of memory called the stack (which parts of memory are reserved for programs to deal with the equipment and devices) tried to use portions of memory outside the specified part
Solution:
Try closing the program and restart your computer.
Message:
A fatal exception 0E has occurred at XX
Meaning:
This error occurred trying to access the data processor located on the Page page of memory RAM or virtual memory Virtual Memory, but discovered the absence of the page, or that the data has been improperly accessed.
Solution:
Close the message and try to continue to use the program, if the program can not switch off and then turn it on again, or restart your computer if necessary College.
Message:
A fatal exception 13 has occurred at XX
Or General Protection Fault
Meaning:
Fault of the same quality as previous mistakes, but did not specify why.
Solution:
Close the message and try to continue to use the program, If you can not do close the program and then restart it again, or restart your computer if necessary College.
All previous mistakes are supposed to occur at intervals spaced opposed, if repeated occurrence tried to determine when those errors occur, if they occur while the program is running, you may be able to solve the problem, remove and then reinstall the software again, or get a version upgrade him.
If you can not link between the error message and a program may be the reason why a file from the Windows system files or one of the device drivers Device Drivers, and test it restart your computer in the security mode Safe Mode, if you do not see the message usually be the cause of one of the players devices Thus you can access the latest version of the drivers in your device through the companies that produce them site on the web, and if the message persists often will be a problem in the Windows system itself, and therefore you will need to re-set the Windows system again.
Message:
System busy and appear on a blue screen
Meaning:
This message appears with the nature of the error usually as stated in previous communications with the program said that the cause of the problem is the system may be Windows itself, and ask you to wait until the system becomes less busier.
Solution:
Restart your computer, and if the error is repeated several times do to deal with him as we have seen in previous communications solutions.
Jun 20, 2013 | Computers & Internet
Hi, I bought DELL INSPIRON 1545 in India two years back... now i am experiencing a trouble in it... It says the following error occurred: Error Code: 0146 Msg: Error Code 2000-0146 Msg: Hard Drive 0...
ok, the good news, the bad news, and the ugly.
Good news: buy a replacement hard drive and you should be good to go. Bad news: data recovery on a failed drive is a crapshoot at best- there are ways to try and recover, but they are stopgap (and cheap) or mostly reliable (and freaking EXPENSIVE)
Ugly: buy an external cage to install the hard drive, use a boot cd of Linux ( I've had better luck pulling files from NTFS drives using Linux than another install of Windows. Go figure....) and put the hard drive in a freezer bag- **** ALL AIR OUT OF THE BAG!. Put drive in freezer for 48 hours.
Pray. Pray hard. Pray harder still. Put drive in external cage, attach to linux system. Pull as much info as you can. Hopefully you can snag your important files- but that error is a pretty gnarly drive error.
Jun 22, 2011 | Computers & Internet
How to recover the permanently deleted files from my 250gb verbatim external harddisc
you can recover deleted files from external hard drive with asoftech data recovery software, you can download the software from
http://www.asoftech.com
Oct 08, 2010 | Verbatim VER95327 USB Hard Drive
Windows cannot recognize my western digital external hard drive. I am getting an error msg: "Windows cannot recognize this device". I need to retrieve my files! Help!
The device has suffered a major failure. If you're lucky it's in the electronics of the case so take it apart, extract the hard disk inside, put it in another external case (or directly inside a desktop) and access it this way. If even then the disk isn't recognized then the hard disk itself has died and all the data on it is lost.
Aug 23, 2010 | Western Digital External USB 2.0 80 GB...
Lost the maps
Depending on how much data needs to be transferred it may pay too get a 2gb or larger SD card as some of these maps are quite large
Jul 10, 2010 | Tomtom ONE GPS Receiver
The file or directory is corrupted and unreadable
You unplugged it when data was still written on it so it was corrupted. Some files are still recoverable so use
http://www.softpedia.com/get/System/Back-Up-and-Recovery/smart-recovery.shtml
to get them.
Jul 03, 2010 | Toshiba 120GB USB 2.0 Portable External...
Error msg
try to format the drive
Feb 25, 2010 | Western Digital Computers & Internet
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Outlook calendar sync error: 03-0058
Did you get a solution to this? I'm in exactly the same situation and nothing is fixing it.
Sep 11, 2005 | Palm Treo 650 Handheld
Gateway GP PC Desktop Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
