How many btu's is a remington 50 kerosene heater
    Brigadier General:
  • 4,736 Answers
When operating properly, the maximum BTU output is 50,000 btu's.
Hope this answered your question. Please be kind enough to take a moment to rate my response. Thanks!
Posted on Mar 25, 2011
It starts up good then stops and a big cloud of smoke comes out. Got a new ignighter (50$) but still doing the same. can you help me?
http://www.bealsmotor.com/manuals/113282-01.pdf You could have an air problem. Take the cover off the heater and see if it runs ok, if it does then you have an air problem, check for bad lines or cracked housings
Oct 16, 2014 | All-Pro Kerosene Garage Shop Heaters - All...
Need a manual for guardian 150000 btu kerosene heater
I need to buy some parts for my guardian kerosene heater 150 btu. Where should i go
Dec 31, 2012 | Reddy Heating & Cooling
I have a remington kerosene heater rem110. i will run a minutes and shuts off. any suggestion as to why?
nancy_holton,
All these type heaters (Reddy, All Pro, Remington and Master heat) were made by DESA international.
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains this common problem, where to get the repair parts and how to do the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 24, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I just bought a remington 45,000 btu salamander. It heats great. although I'm going to have to exchange it because there is a short in the power plug. My question is : is there an additive available to...
i know you can buy kerosene additives to make it smell better.... they are liquid that you mix with the kerosene... but i'm just not sure exactly where to get it.... try like lowes, or home depot, or tractor supply co...... look around anywhere places sell kerosene heaters
Dec 26, 2010 | Desa International (R165DT) Utility Heater
I have 100,000 btu kerosene gibson heater and it runs good with the cover open about 2 inches. If I move it eather way it surges and then shuts off. need help
I had same issue would blow out blue smoke on and off with the cover on . Ran good with the cover off . Checked all the lines made sure all tight and clean .
When I checked the fuel filter it had some resistance not very much so I sprayed it with carb cleaner and blew it out with compressed air and heater is working fine now . It open up about 50% more air flow which is what it needed with the vacuum fuel system .
Jan 12, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Sep 19, 2009 | Reddy Heater 60,000 BTU Kerosene...
Storage
Kerosene does not get stale or go bad like gas. I would make sure the tank is close to full to prevent condensation and just put it away in a dry place. I have stored over 50 each year for many years and have never had any problems.
Mar 18, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
