Do you have to have all the ink cartridges installed just to print out black only
  • 4,737 Answers
Yes, if they are not installed, you'll be prompted to install the missing cartridges. Even if you print only in black, colors are also used to help dry the impressions. It's possible with few printers without color cartridge/s being installed, but most printers don't. Let me know if you need further help. I would also like to know the model and make of your printer.
Good Luck.
Thanks for using FixYa.
Posted on Mar 25, 2011
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Cannot print with only one cartridge
The inkjet printers are designed to print wit BOTH cartridges installed. You cannot fool it to print with only one.
Apr 18, 2009 | Computers & Internet
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
223 people viewed this question
k24674
jasbo
jasbo
