Question about Power Acoustik Car Audio & Video
My protect light is stuck on and all my wiring is correct so i wanna know couuld this problem be dixed
    Scholar:
  • 146 Answers
It sounds like you have a shorted wire or a blown speaker in system
try disconnecting all speakers and see if light goes out if so it is bad speaker if not try disconnecting all speaker wires and see if light goes out then
also if disconnecting speakers fixes problem you might want to check what the Ohm load is and how you have multiple speakers hooked up if Ohm load is too high or low you will get same light
is it possible you have too much moisture in car - sometimnes that will cause error
if this does not help please contact me with as many details as you can give me and i can try to help more - number of speakers, how they are wired to amp, what amp, how many channels for amp, etc - the more info the better i can help
good luck!
Posted on Mar 25, 2011
Wenn mans anschaltet passiert halt dix die "an"
Write please in english , Try to change motherboard RAM
Aug 07, 2011 | ASUS A8N-SLI Deluxe Motherboard
I wanna supplied my Amplifier Lanzar MNX 250 with an 12V - 30 Ohm battery, but the led of my amplifier is red and my speaker doesn't play music. How can I fix the "protect mode" in which the...
  1. The battery is 12 volts and Ohms has nothing to do with your amp installation.
  2. Was the amp running and got hot? Many times an amp will go into "thermal mode" when used for an extended amount of time and need to cool down but I assume if you are trying to hook it up you were not using it.
  3. You need to check the ground wire real well. A loose ground will cause protect mode.
  4. Recheck the speaker wires and their connections. If they cross this to can cause protection mode.
  5. This is a 4 Ohm amp, are your speakers 4 ohm or lower> If not then you may be running to low of a load to your amplifier.
  6. I always remove everything from the amp first and power it on and then add wires and see where which connection throws the amp into power mode.
  7. Check the fuse as well but if the LED is on chances are your fuse is good.
  8. If you check all of the items I listed and the amp still goes into protect mode then your amp is bad.
Regards, Tony
May 05, 2011 | Lanzar MNX250 2Channel Car Amp
My home stereo amp goes into protection mode after about 2 min of being powered on do you know why/
The chances are that it does so due to a faulty part. Often these protection circuits are to detect an overload in either the power supply or the main amp section. Sometimes it's due to a speaker wiring problem, cables that are not suppose to touch - touching. They sometimes reset when either the overload has gone or the wire touching has been corrected. This sounds like it might be too late, and now a semi-conductor (on the heatsink) is acting like a piece of wire! Tripping the circuit. If you get power to the unit (lights etc) then it's probably not the power supply section to blame.
May 24, 2010 | Kenwood Audio Players & Recorders
I got a 1995 ford contour wit the v6 engin and the wiring harness is bad in it is there any way to dix this without havin to buy a new on because a new on is very pricey
Hello....
Because of the complexity and importance of a wiring harness I would recommend that you have it replaced, if you know for sure it is bad.
Good Luck
Mike
Dec 13, 2009 | 1995 Ford Contour
Model c-700 It turns on but the protect light dosent come on. What's wrong with it
protect light only comes on when theres a short or bad earth as long as power light on your all good you never wanna see protect light on cheers mate]
Oct 17, 2009 | Boss REV-700 Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
PROTECTION LIGHT
Disconnect the speaker wires and the RCA cables from the amp. If the protection light still comes on, the output transistors have likely failed.
Nov 02, 2007 | Lanzar VIBE531 Car Audio Amplifier
Power light vs. protect light mode
If the power light on top of the amp is on, the internal power supply is operating.
It is possible that the amp could damage the speaker if it has blown output transistors. Before you connect a speaker to it, you should measure the DC voltage across each pair of speaker terminals. If the DC voltage is more than a fraction of a volt, the amp needs to be repaired.
The amp requires an external fuse. Download the owner's manual from the rockford site.The correct fuse for the amp will be specified in the manual.
Nov 01, 2007 | Rockford Fosgate 800.2 Car Audio Amplifier
Car Audio & Video Logo
374 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
