Question about Kenmore Washing Machines
Kenmore model 110 92573210 clothes washing machine. tub spins violently out of balance. runs thru all other cycles with no issues. with or without water inside. replaced motor to transmission coupling and found problem when attempting to test. Don't know what may have caused coupling to break other than age.
    Brigadier General:
  • 6,277 Answers
If it is STILL out of balance try following my guidance notes ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 25, 2011
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
I own a Kenmore washer Model 110.22722100. The last couple of weeks, it leaves the clothes wet. It drains like it is supposed to and spins. What is causing this to happen?
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Here is the part you will need.
Nov 28, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Wont spin
worth repairing, can likely do yourself. check the lid switch, it is probably your problem. comes complete with wires that plug in. easy fix.
Nov 08, 2009 | Kenmore Washing Machines
Violent shaking on spin cycle
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
133 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
