The cd changer draw was stuck/ jammed, had to force draw open to get cdS out, draw would not shut, so took cover of and basically it's all in bit's', i would like some help on how to put it all back together, where screw's go etc,etc
    Sergeant:
  • 349 Answers
There is a lesson to be learned here. If it doesn't work and you don't fully understand how to dismantle and reassemble an item of equipment, it is better left to an experienced technician. Generally a fault like this is simple to investigate and assess and often fix at low cost. I recommend to all to seek advice from a Technician by asking for an initial inspection and assessment for an agreed and acceptable inspection fee, rather than trying to play Home Handyman on electronic equipment of any kind that you do not technically comprehend.
Posted on Oct 28, 2011
    Problem Solver:
  • 11 Answers
If you forced it open and now have peices everywhere, you will probably need some replacement parts.
You need to post which brand and model serial number.
also; try contacting them to see what parts are available. (Perhaps Ebay also).
Likely is not worth the money unless this is an extremely high end unit......
Posted on Mar 25, 2011
I have a 2001 chrysler town and country. cds got stuck in the 4 cd changer. I took the player out, removed the cds but now cds wont go in all the way and the display reads err. radio works fine, tape...
Sounds like the ejector has become jammed, probably from repeatd failed attempts to eject the stuck cd's.
There isn't much you can do about it, repair on that unit will probably cost more than a better aftermarket replacement
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 11, 2014 | Cars & Trucks
All 6 cds are inside changer and when try to play , an error appears on display.
are you comfortable removing the stereo from the dash board? if it were me, i would remove the stereo then take the cover off of it and try to dislodge any cds which are stuck or jammed
Jul 08, 2011 | Car Audio & Video
Sony CMT-hpx7 - CD changer is stuck with 2 CDs inside. Any ideas how to open it without destroying either the CDs or the stereo? Any help would be appreciated!
it a bit complicate to open
you can try but you need to remember what you open so you can put back in the same order
try this
first open the back cover you should be able the see the inside then you need to open the top cover now the changer can be open without power you need to locate the motor and turn the the belt or the wheel slowly and it wil take the disc out. """"""dont turb back""
you need to plug the power and let it go back alone after that disconnect the power and put back everything
its not so easy so before you do it make sure that you can open and put back
Hope it will help
Aug 24, 2010 | Sony CMT-HPX9 CD Shelf System
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
Apr 09, 2010 | JVC XL-F254BK 5-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
6 CD Changer Jammed (Audi A4)
You may have to remove the unit and disassemble it to remove the CD that evidently is jammed inside. If your unit has a removable magazine that holds the CDs, the magazine probably is stuck.
Oct 22, 2017 | Car Audio & Video
Sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Jun 24, 2009 | Sony CHC-CL1 CD Shelf System
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
80 people viewed this question
 Grubhead
Grubhead
