Question about Singer Inspiration 4210 Mechanical Sewing Machine
LOI NEED TO KNOW EXACTLY HOW TO PLACE THE BOBBIN CASE IN THE MACHINE. IT SEEMS TO BE WAY TOO LOOSE. WILL NOT SEW PROPERLY. IT STARTS TO JUMP OUT.
    Scholar:
  • 89 Answers
Sounds like you may not be threading the top thread correctly.
thread the top thead all the way to the needle but not the eye. Then lift the presser foot up and down. You should have tension when the presser foot is down and no tension when it is up.
If this is the case try sewing, if not your machine needs adjusting.
hope this helps
Posted on Mar 25, 2011
Bobbin holdernkeeps jumping put
If the bobbin case is not seated properly and latched into place, it will jump out of position when you begin to sew. Consult your owner's manual to see how to install the bobbin case properly into your machine.
Mar 05, 2016 | Sewing Machines
Bobbin case wont stay in place when I sew
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Apr 01, 2015 | Sewing Machines
Touch n sew 778's bobbin case pops out when I try to sew or thread the bobbin. little hook on the upper left side of the bobbin area seems to be stopping the casing from rotating. any ideas?
you've probably got the bobbin in wrong. No one ever seems to know this... a bobbin when it's pulled out of the case needs to pull against the open edge and not with it... it's hard to explain, but it needs to unwind in a specific way - either clockwise or counter-clockwise.... each machine is different, but depending on the bobbin case that you put it into, if it doesn't work one way, turn the bobbin over and let it come out the other way... usually fixes this like a charm!
Mar 18, 2015 | Sewing Machines
I have a singer touch n sew model 638. All parts seem to be working, except when I try to sew, no thread is left in the fabric. Also, when I use the pedal, I have to push it pretty far, and when it finally...
Make sure the divot in the needle is facing the bobbin case.
Thread can be wound up in the rear of the bobbin case causing a delayed advance... This is often not visible when bobbin is removed.
Jun 01, 2017 | Singer Sewing Machines
Loose Bobbin Case on Singer 4830
Your first step is to go to the Singer site and download your user manual -- it's available free. You need to check to make sure that you are inserting it properly in the first place. Please keep in mind that the bobbin does NOT turn--the thread unwinds from the stationery bobbin.
Next, I would manually sew using the hand wheel and no fabric with the needle plate off and observe what it's doing. You CAN replace the bobbin case if necessary.
Jun 30, 2017 | Singer 4830
Thread is 'snagging' in the bobbin case
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 18, 2009 | Sewing Machines
I have rewound a bobbin on my sewpro sewing machine. When I loaded the bobbin back in the machine I can't get the machine to pick up the thread to sew again.
Welcome to FixYa. I always try the easiest fixes first - make sure your bobbin is inserted correctly, and that the bobbin thread is securely threaded in the bobbin case (sometimes the bobbin thread doesn't "catch" when you place it in the bobbin case). If all is well in the bobbin area, rethread your machine. Make sure that the presser foot is in the raised position when you thread. If it still isn't sewing correctly, change your needle. These last three steps fix most problems. But, if you are still having problems, look at the thread in the problem bobbin. It should be straight and tight. If it is kind of wobbly and a little loose, you'll need to wind the thread onto a new bobbin.
If are new to sewing, keep your manual close by and refer to it often. Simple mistakes can make a new sewer loose confidence, but it is all part of the process of learning your machine.
Good luck and happy sewing. If you have a sec, please rate my response so I know when I need to work on my responses.
Thanks for stopping in. Ginny
Jan 28, 2009 | Sew Pro QuickStitch SP-402 Mechanical...
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Singer 3820 How I replace the bobbin case, it's loose and I can't sew!
remove the 2 screws in the needle plate. Lift off the plate.Take out the bobbin case and examine it for rough spots or nicks. If there are any it will be necessary to buff them with an emery stick or fine sandpaper. Once the rough spot has has been smoothed, buff it with some very fine steel wool. There must be no rough spots on this bobbin case.Clean all the lint from inside the hook area. Do not pull the wick from the center of the hook. Place the bobbin case in the hook area so that it sits flush and does not bind when the handwheel is turned.Reinstall the needle plate, thread the machine, insert the bobbin and turn the wheel to pick up the bobbin thread and see that it doesn't bind.Test sew
Jun 10, 2008 | Singer 3820 Mechanical Sewing Machine
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Singer Inspiration 4210 Mechanical Sewing Machine Logo
116 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
