Question about GE GTS22WCP Top Freezer Refrigerator
My 9-year-old refrig (GE GTS22WC) frequently does not cool because the compressor does not work, but everytime I ordered an new refrig to replace it, suddenly we found it works again. We doubt the temperture controller does not work properly. What do you think what would be the problem most likely? Should I get it fixed or replaced. Thanks a lot.
  • 57 Answers
The GE refridgerators are known for bad mother boards (or circuit boards). The relay gets carbon tracking and causes arcing until it finally burns out. I am a mechanical engineer and I work with an electrical engineer. Our GE fridges went out in the same week. A place called appliance parts pros dot com had our parts in stock and we could order through the net on their website. The part is roughly 150.00 including shipping. By the way, your unit started working again because the relay is making contact temporarily. It will fail again.
Posted on Dec 12, 2015
    Habit-Forming:
  • 139 Answers
Ok this is more than likey cold control problem. I look up on sears found the part number. It is WR09X10104 and it is only 30 dollars. I would give a try. The part is located in that long piece in the center. Unplug the box. Remove the four 1/4 screws. Pull down center piece. It will have a gang plug. Unplug it so you can change the cold control. Reverse the order This will solve your problem.
Posted on Aug 31, 2011
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Compressor won't work. the fan runs but not the compressor
Well, unfortunately you will have to replace the compressor.
you might as well replace the refrigerator for a brand new one since replacinng the compressor isn't economical.
As an appliance repair ny company we handle this issues frequently and replacing the compressor would cost you over $400
Hope it helped.
Oct 17, 2010 | GE Refrigerators
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
G E side by side refrigerator is not working properly....
Could be the start relay device on the compressor. Does it try to start every minute or so?
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Everytime the compressor stops there is a loud 'bang' sound.
When the compressor stops, the movements of the internal components are normally absorbed by the internal spring supports. If a spring breaks, etc., the inner moving part will contact the outer case and give a knocking noise or two when it stops. You can make the compressor (even a new one) do this by giving it a shake. The compressor will most likely run for years this way with no performance problems. It is rather expensive to replace a compressor, (especially for only a noise issue) so most people just live with it or get a new refrig and use their old one as a second refrig in a basement or where ever. Please don't bother to rate this, as anything but a Fix-Ya drops my score.
Jan 20, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrig runs short time and shuts off
could be a sensor, 6 dollars, could be the mother board, could be the compressor or overload, could be encoder board i would call factory service, some of these parts are high dollar
Apr 12, 2008 | Refrigerators
GE GTS22WCP Top Freezer Refrigerator Logo
406 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
