My Samsung DVD TV 15G10 is 3 years old and has functioned perfectly until the other day when I turned it on to view and since have had only sound and no picture. Grateful for any thoughts on how to remedy the problem please
    Scholar:
  • 146 Answers
Firstly i dont know how the video is hooked up to tv - so if what i recommend doesnt work i would suggest giving more details
if video is hooked up to tv through component video (red, green, blue wires) try checking the green wire- if green wire is bad you will get no video on your screen you can try using one of the other wires to test if you dont have a new component video wire to try
secondly if that doesnt work try hooking the source up to a different input on tv and see if that works
next i would try another source for your video to be hooked up to tv ( maybe a dvd player or something like that)
if all of those tries dont work you might either have had the bulb for the back light go bad ( backlight bulb is usually a flourescent light bulb and it makes the screen get bright so you can see it) or the power supply for either the backlight bulb or the video high voltage go bad in which case i would recommend bringing in for service or just buying a new replacement (they are fairly cheap to buy new now so it might be a better alternative to a repair)
sometimes you can tell if it is backlight problem by making room very dark and look carefully at screen to see if you can see a picture on it - if you see a faint picture on screen then it is definately your backlight that went out
if you need more help write back with as many details you can give me about what wires you have connected things to tv with and what sources you have connected to tv also
good luck!
Posted on Mar 25, 2011
RCA 32 Smart Tv SLD32A30RQ Will turn but nothing happens and has a blank screen.
It sounds like the internal calendar function is working perfectly.
Nov 12, 2015 | RCA Televison & Video
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Jan 31, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
TV screen went blank and it began clicking, turning itself on/off repeatedly. Had to unplug from wall to make it stop. TV is only 2 years old and has worked perfectly until now.
the power supply board has failed. call 1-800-samsung for nearest service center. power supplies are usually $125.00 plus labor, 1 hour maximum to repair.
Nov 24, 2009 | Samsung LN-T4665F 46 in. LCD Television
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Apr 07, 2008 | Televison & Video
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
