Question about GE 24 in. GSD6200G Built-in Dishwasher
My diswasher will not drain, it seems to have completed the cycle but the basin is full of water when it finishes.
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Mar 26, 2011
Dishwasher whirlpool model number du1030xtkq2 will not finish cycle
Check the float to be sure it is unstuck. Sometimes this item [on the basin of the DW, looks like a mushroom. Measures the water level in the bottom of DW] is tricked in thinking it has water, or the water is not turned on, or the basin is full. Gently pull up on it and push down on it. Does it move freely?
Try to cycle again.
Nov 24, 2013 | Whirlpool Dishwashers
My whirlpool dishwasher is not draining completely. It runs through the entire cycle with no problems, except that after it has finished, there is a layer of water on the bottom of the diswasher.
Hi, there will always be some water in the bottom the tub. This is called the sump. When your pump stops draining, all the water that's up in the hose will drain back into the sump. You failed to tell me how much water is there. If a small amount then it's normal, however if it's a large amount that covers 1/2" or so then you indeed have a problem and snaking out the lateral should clear it up.
Jun 28, 2011 | Whirlpool Dishwashers
KitchenAid KUDR24SE dishwasher doesn't drain.
check the drain tube at the disposer
Jul 02, 2009 | Dishwashers
Bosch Diswasher won't pump water out after cycle
it needs a new drain pump for around $65 dollars. the install will take close to $90-$120.
Apr 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Washer wont complete cycle. its full of water and I cant drain it
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
Nov 30, 2008 | Kenmore 24902 Top Load Washer
Won't get off drain/cancel cycle
It sounds to me like you may have a float switch that is registering water in the unit when you try to start it. If the unit "registers"that there is water in the sump before starting a new cycle, it will try to drain it before starting. The switch is located under the lower acess panel. Sometimes, you can bounce the float (depending on model) inside the unit a couple times and dislodge it. If not, you will have to pull the lower acess panel and check the switch out.
Oct 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Cycles improperly
hi there,
please let me know the make and full model # off your d/w.
thanks
Mar 26, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE 24 in. GSD6200G Built-in Dishwasher Logo
96 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
