Question about Hansgrohe 06341620 Kitchen Soap Dispenser Oil Rub Bronze
I have hans grohe axor terrano soap dispensors and they will only deliver a drop of liquid when it works at all. I tried priming and diluting. No luck. Any fix or replacement pump?
4 Suggested Answers
  • 225 Answers
SOURCE: Plugged dispensor of the liquid soap at kitchen sink.
soak it in hot water and try pumping it every so often,should loosen liquid soap.
Posted on Jun 14, 2009
jyackle5
  • 8197 Answers
SOURCE: my grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Posted on Apr 02, 2010
HANSGROHE US
  • 7 Answers
SOURCE: What tool is needed to
This is a pretty difficult model to work on because the bonnet nut is so slim. The way I do it is to dismantle the faucet from the sink. Remove the cap and handle (2mm set screw) and lay the faucet on it's side. Protect the finish by putting it on a towel and lay it on a firm surface such as a table or work bench. Leaving the body and spout on the table, hang the top of the faucet over the edge of the work surface. Carefully lock vice grips onto the nut. Be careful to use just enough tension to secure it to the nut. Dont go too hard, or you will just chew up the nut. Then lightly tap the channel locks with a small hammer or mallet to turn the nut counter clockwise. Do this while pressing down on the faucet body to keep it from jumping. Lots of little taps will loosen the nut which is locked in by mineral deposits from leaking. Once the nut is moving you no longer need to tap it, as it can then be turned by using your hand to turn the vise grip pliars.
Look for an old o-ring in the nut where it meets the top of the cartridge and replace it with the supplied new one. Also replace the two seat washers that sit in the faucet body at the base of the cartridge with the supplied new ones. The newer cartridge will be smaller diameter, but you will see that the height is the same and it works perfectly.
Lastly, if this is all too difficult, Hansgrohe will allow you to send your faucet in under the warranty. We will repair, test, and send it back to you. You can call us at 800-334-0455 for service in USA, or contact us through the web site www.hansgrohe-usa.com
Posted on Sep 02, 2011
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
I have a axor Grohe shower head ona rail. It is starting to slide down the rail on it own.
There may be a tension adjustment screw on the slider that you can adjust to add tension between the slider and bar. If it is an Axor or Hansgrohe wall bar You can call Hansgrohe Technical services. We can help you identify and adjust or reapir this unit. Feel free to give me a call at 1-800-334-0455. Ask for David Scarborough. I'd be happy to help.
Aug 23, 2012 | Home
I have a Grohe liquid soap dispenser and the washer is leaking soap at the base of the unit. can this washer be replaced?
it is not available from Grohe but if you take it apart it is probably generic enough to be found at your local hardware store. assuming this the problem. it may just need to be tightened up a little. either way here is a link, w/an adobe file (specification sheet), regarding the specs about 1/3 down the page on the left. you can also purchase the soap dispenser here. hope this helps:)
http://www.faucetdirect.com/grohe-28-751-deck-mounted-soap-dispenser/p54966
Jul 26, 2011 | Grohe Soap/Lotion Dispenser 28.857.AV0
My grohe soap dispenser won't pump out any soap.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
My grohe soap dispenser sticks. I cannot get it to pump. I've soaked it in vinegar to de-gunk it - what else to do?
You may be using too thick of a liquid in it palmolive is the worst to use in soap dispensers flush the head out with water if you remove the tube from it be careful alot of them have a ballbearing or spring inside or the unit is worn
Nov 15, 2009 | Grohe Satin Nickel Soap Dispenser...
Do you have to use the automatic detergent dispenser on the maytag atlantis? Or can I just add detergent to the tub myself when starting a load?
Formerly Maytag Service:
It is actually better for your machine to add the soap directly to the tub, during your fill cycle, than it is to use the dispensor.
Just ensure that your soap or detergentg is color safe, so that direct contact will not damgae your cloths.
Thats the only reason the dispensor was ever made,
so that the soap could be dilutted before contact with fabric
hope this helps
Oct 18, 2009 | Washing Machines
May 25, 2009 | American Standard Contemporary Kitchen...
I have a Grohe dish soap dispenser that get clogged-? soap
Dilute the soap you use by 1/3 . this won't affect the soaps ability to clean, but it makes it easier on the dispenser.
Jan 16, 2018 | Whirlpool GU2400XTP Built-in Dishwasher
Need to dissolve hard soap
The internals of a dishwasher are stainless steel and plastic and for these sort of problems a diluted solution oh hydrocloric acid can do the trick......just wear gloves!!!
Jul 26, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Hansgrohe 06341620 Kitchen Soap Dispenser Oil Rub Bronze Logo
35 people viewed this question
Top Hansgrohe Home Experts
ray gallant
Daryl Gleaton
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
