Question about Toshiba Satellite A15-S129 Notebook
I have a Toshiba Satellite A15-S129 and want to replace my DVD Drive with a DVD RW. How do I remove the old one and replace with the new one?
  • gcar325 Mar 25, 2011
    There is no latch underneath there is a screw directly under the DVD but it didn't slide out. Do you have any other suggestions?
  • 253 Answers
SOURCE: replace cd rom with a dvd+rw cd rom in a toshiba satellite
You should be able to, there is usually only one screw holding the drive in, if you hold the replacement up to where the instlled one is, you should see the approximate location of the screw ( may be under another panel, Memory,hard drive etc.., the drive will just slide out, then make sure the connectors are the same, and swap or place the mounting bracket on the new one, and slide it back in place, replacing any screws removed
Posted on Mar 30, 2009
AvioriX
  • 689 Answers
SOURCE: Toshiba Satellite A15-S129 PC Notebook
Have you turn the wireless antenna switch on?
Posted on Mar 31, 2009
vortash
  • 431 Answers
SOURCE: toshiba satellite a15-s129
Hi I am Vortash .. the best thing to try first would be starting it up in safe mode , Turn on and keep pressing f8 this should trigger the safe mode screen and choose start in safe mode only no drivers no network
if it works ok like that , then shut down and start normally turn on and allow to start normally then click start accessories system tools and then restore ... hopefully that will work .. if not see if it will restore in safe mode .. if they both fail you probably have a faulty hard drive or the interface where the computer is connected to the hard drive .. to check use an external hard drive ( usb) with an operating system on and the bios in the computer set to boot from removable in one of the boot options .... if it does boot up like that check the pins on the hard drive are not damaged or dirty ( you don't know how long it was in that garage lol ) if the interface connection is faulty there is not a lot you can do about that as it takes specialist equipment to repair multi layered surface mounted boards .. hope this helps Vortash
Posted on May 17, 2009
  • 66 Answers
SOURCE: I replaced motherboard on my Toshiba A15 - S129
You need to run the dmi utility. if you go on toshiba's support site it should be there. if not email me and i will send it to you.
Posted on Nov 04, 2009
Testimonial: "Thank you so much!!!)))))) Jozef"
support506
  • 3 Answers
SOURCE: how can i full recovery of my pc
You have a bad hard drive...probably. I hope it's a bad hard drive, the other possibility is a mobo and that's a whole lot pricier. Order this drive and swap it out with your current one. I can't be 100% sure, but in every laptop that I've seen with a write sector failure on reload, it results from a bad hd.
get this one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
Posted on Nov 10, 2009
My soninlaw put a bigger hard disk into an old
Get the new power supply for it. I don't see the HDD causing it to go out.
Apr 27, 2010 | Toshiba Satellite A15-S129 Notebook
How can i full recovery of my pc
get this one.
Nov 10, 2009 | Toshiba Satellite A15-S129 Notebook
I replaced motherboard on my Toshiba A15 - S129 and now y model is A10. Is it possible to change that to A15. I can't use restore CD because of that. Please help.
Nov 04, 2009 | Toshiba Satellite A15-S129 Notebook
Hello, Can I install a 512MB DDR DIMM, N mem stick taken out of my Dell Desktop into a Toshiba Satellite A15, S129 laptop? Thanks, RD
You can try, without fear of having your laptop "blow-up".
Turn your laptop off.
Remove the battery.
Physically, does the RAM fit into the RAM slot? If not, the answer is 'no' -- most "desktop" RAM is much bigger than most "notebook" RAM.
If it fits, connect the AC power, and turn the computer on.
If it beeps wildly, or does not beep at all, the RAM is incompatible.
Disconnect the AC power.
Remove the RAM.
Re-insert the "old" RAM.
Re-insert the battery.
Reconnect the AC power.
Do a Google-search for "RAM upgrade Satellite A15" to find sellers that sell compatible RAM.
Oct 10, 2009 | Toshiba Satellite A15-S129 Notebook
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
Hard drive crashed
Nope, it's just a matter of pulling the old hard drive and putting in the new one. Sometimes there will be an adapter attached to your old drive that you'll have to transfer over to the new one. What you need is a 2.5" mobile PATA (IDE) drive.
May 28, 2009 | Toshiba Satellite A15-S129 Notebook
Mar 31, 2009 | Toshiba Satellite A15-S129 Notebook
DVD Rom
try re-installing the device drivers to sort the problem
Nov 18, 2008 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
