Question about ViewSonic VA2226w 22" Widescreen LCD Monitor
Viewsonic - VA2226w - dual monitor configuration. Monitor is black / no image- all test pass showing monitor is functioning properly.
  • 1,591 Answers
Swap this monitor with the main one.
If it works, you may simply not have the secondary output enabled in the operating system.
In Windows for example, in the video properties, there's a place where you choose which video card you're dealing with (and/or which output or monitor) and there's a checkbox that says "extend my desktop to this monitor"
If that's not enabled, monitor 2 will be blank !
If the monitor doesn't work in the same connector that the working monitor is in, you may have bad capacitors in this one.
Watch the video below on how to fix that issue.
Posted on Mar 25, 2011
Testimonial: "Thanks, great answer, I believe this is my problem and give it a try."
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
My view sonic va2226w monitor is black but blue power button keeps blinking
Check for bad caps with bulging/leaking tops as shown here first:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VA2226W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | ViewSonic VA2226W LCD Monitor
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226W LCD Monitor unlock power button
Try holding the vol+ & vol- or hold the vol+ & Menu and lastly try the ch+ & ch- buttons. When doing this you must do it from the tv not the remote, and hold them down for ten seconds or until it says it has unlocked.
Apr 04, 2010 | ViewSonic VA2226W LCD Monitor
When Monitor has been switched off for 8 hours it takes 5 minutes to get back up again. Once up it will work perfectlt
This monitor is more than 2 years old, time to look for bad caps with bulging top in the power supply, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
Installing Ubuntu after vista install gives "out of range"
http://www.tech-tips-now.com/2008/11/12/how-to-dual-boot-vista-and-ubuntu-810-part-7/
this is great guide to set up a dual boot option on your on pc
Mar 16, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
New monitor only shows my desktop image. and nothing else
it is not monitor problem as it is showing desktop. there is problem in setting of monitor or monitor Configuration is not proper. please refer manual which you must have received at the time of purchase.
Sep 27, 2007 | Computers & Internet
ViewSonic VA2226w 22" Widescreen LCD Monitor Logo
280 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
