Question about BMW Car Audio & Video
I found water in around amp in battery compartment on bmw z4 changed the amp and cd head unit cleaned the connector for the amp checked and reseated the fuses and still have no sound anyone have any clue wats going on how do i get sound
    Renaissance:
    An user who is expert in 3 categories / brands.
  • BMW Master
  • 2,226 Answers
You may have to take the amp apart and clean any corrosion off inside of the amp. if the corrosion ate any of the leads of components or any traces, you may have to replace the amp. this is assuming it is the factory amp you are talking about.
Posted on Mar 25, 2011
My battery died and when I jumped it the car started but the dash is blank. the windows, radio and A/C work fine. Do I have to reset something?
bmw z4 alternator - forum about car parts and car advices ...
abmforum.com/bmw-z4-alternator.html
bmw z4 alternator help cracked alternator upper mount 2003 z4 head light ... Before putting my car in storage a few months ago my old battery was nearly dead I needed to... in a Z4) but the same big yellow battery light is still on my dash appearing for .... Hi guys I own a 2005 Z4 2.5i Auto and there is a weird whining sound.
x3 wont start... charged battery and still died, ideas ...
www.bimmerfest.com > ... > X Series > X3 E83 (2004 - 2010)
Aug 30, 2013 - 13 posts - ‎6 authors
OK, long story but here it goes (hopefully the length will help with ... I hook the jumpstarter up to the battery, let it sit 1-2 minutes, then ... The AZ rep. tells me that my battery is at 9V and this is why my car .... Mein Auto: 2004 X3 2.5i ... If battery is original (2005) it is more than likely one cell has shorted out. Z4 starter motor and related problems.
Nov 1, 2015
First time BMW owner '03 Z4 - List of current issues
Apr 25, 2015
Eml light on, engine shakes, no response from accelerator ...
Apr 29, 2012
SOS need Z3 radio code
Jun 18, 2011
More results from www.bimmerfest.com
Thread: 04 Z4 Won't Start - Roadfly Car Forum & Off Topic Forum ...
forum.roadfly.com > ... > BMW Z4 Roadster & M Roadster (E85)
Mar 5, 2008 - 20 posts - ‎6 authors
I could not start my Z this morning after not driving it for the past 4 days because of the weather. All lights come on the dash including the head lights but it won't crank. ... If the starter is not cranking because of the battery being too drained .... BMW Z4 2.5i started slow and finally would make a clicking noise.
Z4M Engine Sputters/Misfires - Bimmerforums
Jan 06, 2016 | 2005 BMW Z4 2.5i
After jump starting 2006 Z4 BMW headlight low beams don't work checked fuses in glove compartment and under hood all seemed to be ok is there a relay, what do i do now
If the lights are switched then the switch controls a rely all lights are switched on bmw. Can use fog lights temporarily. Find rely test with continuity meter when on, disconnect lights first, then turn on lights switch, check for 12v at light bulb terms, if 12v then bulbs bad, if not relay is bad, test with continuity meter, rely should read 0 ohms when lights switched on, infinite open circuit when switched off. If lights work in manual switch pos then solar sensor bad.
Dec 05, 2012 | 2006 BMW Z4 Roadster
What type of battery is required for a bmw z4 3.0 convertible Can you purchase a battery for a BMW z4 at any locat auto parts store
BMW Z4s need a special type of vented battery. The closest alternative to the OEM battery would be the Interstate MPT-H6 which you should be able to purchase from any place carrying Interstate batteries (most places do).
Jan 19, 2011 | 2006 BMW Z4 Roadster
How many amp is the battery for z4 3.0 2004? thanx
There are three different amp that you may use for the z4...520 cold cranking amp (650 cranking amps), 600 cold cranking amps (750 cranking amps) or 730 cold cranking amps (912 cranking amps). Hope this helps.
Jun 20, 2010 | 2004 BMW Z4
Need a 2003 BMW, z4, 2.5, water pump diagram
CLICK on the following LINK. It has the Belt Diagram you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2003/make/bmw/model/z4/2003_bmw_z4_drive_belt_routing_diagram.htm
Mar 09, 2010 | 2003 BMW Z4
How can i change (replace) a 2004 Z4?
I said last time, pull upward with great force! Holds a lot, but no screws!
Warning!
pulling the knob head then there is when it is then that you can knock - out to the chin, really!
Feb 19, 2010 | 2004 BMW Z4
Where is the battery for the 2006 z4
In the boot on the right hand side. You remove the peice of trim with the little shelf on the bottom and its under that. For jump starting though, there are points under the bonnet.
Dec 12, 2009 | 2006 BMW Z4 Roadster
My childs batery opperated bmw z4 is not charging
Take the battery to be tested.. A typical life span of a battery is around 3 years and it might need to be replaced.. Be sure the connections on the battery are very sucure.. if they are loose the battery will not charge properly.. If the battery is good - have the charging sytem tested.. It could be a bad altimator..
Sep 21, 2009 | 2007 BMW Z4 Roadster 3.0si Convertible
Car Audio & Video Logo
177 people viewed this question
Top BMW Car Audio & Video Experts
xxxxxx xxx
Joseph Hoffmann
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
