Question about Sanyo Televison & Video
How do I get the dvd drawer to open if for some reason it is jammed
  • Sanyo Master
  • 6,993 Answers
To get the DVD drawer opened, you must disassemble the player first.
Turn of the player and remove it from the wall.
Get a screw driver that can fit into the screws of the player. Unscrew all the screws and open the player's top cover.
After the player has been opened in such way that you can see the mechanism, go straight to that part. The mechanism is that part of the player where the DVD enters into, including the disc tray/drawer. The mechanism is made of plastic.
First, check if you will find any object preventing the drawer from coming out. Plug the player into the wall turn it on and press the eject button, you might find what's preventing it from coming out. But if don't find any object, read further......
At the front of the mechanism, you you will find a plastic controlling the drawer, use the screw driver to press the plastic and the drawer should come out. Study the disc tray very well and you will find the plastic controlling the drawer.
Good luck.
Posted on Mar 25, 2011
Why won't the cash compartment open?
number of reasons possible
check paper if it prints out a receipt each time. Have seen this occur in Fast Food store. Cash register would not open.
If you can get the drawer out check behind drawer for foreign objects.
Check coins are not jamming drawer
could be a faulty solenoid that pulls lever to electronically open drawer.
Dec 31, 2015 | Retail Supplies
HOW DO I REMOVE DVD DISK FROM TV
Press the little button on the DVD drawer. If it is jammed and you can see a small hole in the drawer, open up a paper clip and make it nice and straight with pliers. Insert this into the hole and push firmly and the drawer will pop open.
Also look on the remote for an EJECT command.
The blurb is here, but no manual for download.
19 Class LED Widescreen HDTV with DVD Player
Sep 12, 2015 | Supersonic 19 Inch SC-1912 12 Volt AC/DC...
How do I manually open dvd drawer
There may be a DVD jammed in the drive or the drive eject mechanism may have failed.
Sep 11, 2014 | Televison & Video
Dvd or cd are not open
I think you are saying that the CD/DVD drive drawer will not open?
Most drives have a tiny hole above the drawer. You need to straighten out a paper clip ,then poke it into the hole. This should release the drawer catch and you can open it by gently pulling. It may be jammed as a disk was not properly seated inside.
Check on My Computer that your computer recognises the CD/DVD player is there.
Mar 03, 2014 | Panasonic SC-PM39D System
Dvd is jammed
If the DVD player/drive door or drawer will not open, try taking a regular metal paper clip, straightening it out, and inserting it into the small hole that releases the cover. Use a flashlight to look for this little hole, insert the paper clip straight in, and press firmly. The door/drawer should come open.
Oct 21, 2013 | Computers & Internet
Stuck dvd player disc drawer
The gears have jammed, or the timing gears are out of sync, or a broken loading belt.
Mar 25, 2012 | Koss Televison & Video
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
Cannot get cd drawer to open. LCD says load, but
take the top cover off and have a look at the dvd,which has probably come off the tray. it is jammed for some reason
Aug 18, 2009 | Toshiba SD-K760 DVD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Televison & Video Logo
67 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
