No sound and solid blue screen - Televison & Video
  • 1,591 Answers
That's usually a sign of no input.
Check which input is being used, and make sure the TV is in the correct mode for that connector.
for example, if your input is going into the AV connectors on the TV, make sure the tv is set to AV and not cable or antenna or something like that.
If that turns out to not be the issue, come back here and use the REPLY link to post a follow up.
Posted on Mar 25, 2011
Westinghouse ltv-46w1 hd
Test the various power supply voltages first if your able to be sure they're ok, if they are it could be the main or Tcon board that is bad
Mar 20, 2018 | Westinghouse Televison & Video
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
When i turn on my tv i can hear the sounds but my whole screen is blue
do you see thin curved blue lines going from bottomto top of screen. If so its most likley a blue CRT drive board issue. If its a solid blue it could be a small signal board issue.
Aug 04, 2011 | RCA Scenium D40W20 40" Rear Projection...
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
The screen has blue dots and solid blue patches that are spreading.
Optical block is deed,Sony have recall on this prob.get ur warenty repair.
Sep 15, 2009 | Sony KDF-42WE655 Television
I have a polaroid 42 inch flat screen and the screen is solid blue when i plug my cable in it is black I can here sound but no picture it is a 2007 module tlx-04240b
Make sure all the connections are correct, a "blue" screen indicates no-signal, black indicates some type of signal is getting to the tv. good luck Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
i have sound but no picture, or i have sound and a picture for a few minutes then it either go to a solid blue screen or pink and blue lines. this tv is only 7 months old
Nov 26, 2007 | Audiovox AVT1498 TV
Sound problem
sounds like you have the antenna wire connected to the power amplifer lead in the car.
Go behind the radio, there is a solid blue wire that will be connected to a wire in the car, take the solid blue wire off, and connect the blue/white from the radio to where the solid blue was originally connected. This should solve your problem
Nov 24, 2007 | Jensen VM9410 Car DVD Player
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
