Question about Hyundai Electronics N220W 22 inch LCD Monitor
Hyundai U220WD LCD monitor displays OFF MODE (on a black backgroung). How do I restore the display? What does the MWE button do?
    Guru:
  • 679 Answers
Hi
If the screen is connected to a computer usually its a video card/ video cable problem and not the LCD monitor. Try to check the video cable look for loose connection or bent pins, if none try using a different video cable or checked the video card component of the computer too see if its still working,. Your monitor is dependent to your video card signal inside the computer. Without the signal monitor will not work.
thanks for using Fixya
Posted on Mar 25, 2011
As soon as I turn on the Hyundai X93W monitor, it stays on for a couple of seconds, then the screen goes black, but the green light next to the power button is still on. I'm not sure when this problem...
josealvajr, Check YOUTUBE again!! Use search terms: "lcd monitor repair" and "lcd monitor disassembly" and you will find some video clips that may not be for your unit, but will help you. All ccfl back-lit lcd monitors use same basic electronic design to display text and images on the lcd panel!!! Hyundai probably won't sell you a inverter/smps board. Look for swollen capacitors on the power supply board. Lots of pic's on web for you to look at. 12fixlouie
Oct 19, 2010 | Hyundai Electronics Hyundai LCD 19"...
I have a hyundai monitor which keeps switching itself off Displays the computer screen then goes into energy saving mode after a second or so Help!
alastairhaig, Is unit 4 years old? Could be problem with units switch-mode-power-supply if same thing occurs when connected to fully functioning different pc that has all screen saver and power save features disabled. After screen goes "black" do you still see the WIN-desktop screen and icon's if you hold a bright flashlight at different angles about 1 inch from the screen? SEE = power supply in "partial shutdown" mode. NO SEE = smps in "full shutdown" mode. Do some reading in my fixya profile about "black screen of death" repairs. also read FIXYA profiles of "budmrtn" "buddymc" and other fine profiles of technicians here on fixya. You will truly be amazed when you visit YOUTUBE for video clips of owners/technicians who save their cold cathode fluorescent lamp, back-lit lcd monitors from the "trash-heap"!!! After you do your research please return here and rate this response and possibly do additional comment. 12fixlouie
Oct 12, 2010 | Hyundai Electronics Hyundai N91W (Black)...
Backlight of Hyundai X93W dead
The fault is most likely a faulty inverter board.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site :-
www.lcdparts.net
Jan 09, 2010 | Hyundai Electronics Hyundai LCD 19"...
How do you turn off the flash on samsung sl202
When the menu is displayed on the LCD monitor, pressing the LEFT button makes the cursor shift to the left tab. When the menu is not displayed on the LCD monitor, the LEFT button operates as the FLASH ( ) button.  Selecting the flash mode 1. Select a desired Recording mode, except the [Movie] mode and the [DIS] mode. 2. Press the Flash button until the desired flash mode is displayed on the LCD monitor 4268flashicon.jpg The flash does not fire. Select this mode when capturing images in a place or situation where flash photography is prohibited. When you capture an image in poorly lit conditions, the camera shake warning indicator ( ã ) will appear on the LCD monitor.
Oct 24, 2009 | Samsung SL202 Digital Camera
No display powershot a75
Did you get a solution to your problem? I am experiencing the exact same thing with my A75. Still takes pictures and displays them for the 2 second preview, then back to black. And they download fine, too. But I get the same black screen in every mode except stitch assist and movie mode. Thanks.
Jun 06, 2009 | Canon PowerShot A75 Digital Camera
Display settings are out of range
you going to go to safe mode and try to restore you system to the date that you not change the video settings of computer just go to start button goto accessories click system tools and click system restore
Mar 11, 2009 | iiyama ProLite E380S-B (Black) 15" LCD...
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
My SVA monitor 5 blacks out after 5 seconds
use f 8 to go to safe mode then set the resolution at the very least liek 8 bits or whatever the lower=st is and save it then restart in normal mode and then play with the resolution in display settings to get to the ma your video card will support.
Jun 19, 2008 | Gateway FPD2275W LCD Monitor
Flash
the left tab.
■ When the menu is not displayed on the LCD
( ) button.
● Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of MOVIE CLIP mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Hyundai Electronics N220W  22 inch LCD Monitor Logo
160 people viewed this question
Top Hyundai Electronics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Hyundai Electronics Computer and Internet Expert? Answer questions, earn points and help others
