Question about Sony BRAVIA KDL52XBR2 Television
The On screen tv guide has stopped working. What could be the problem?
  • 158 Answers
Do you run a cable box from your cable provider with digital service?
Posted on Mar 25, 2011
TV stopped working. When turned on the word POLAROID stays on
The repair bill will be $200~250 range if you can find the shop that willing to try to fix it and find the parts for you.
You can learn from my guide here:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 27, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
TV guide abruptly stopped receiving information
Off-Air reception (Antenna) of TV Guide comes from a supplier called Rovi (formally known as Macrovision, Gemstar). They have supplied your local CBS affiliate with a TV Guide application known as SCTE 127 or VBI in MPEG. Follow these steps until you have found a solution to the TV Guide - No Information Available.
1. Check to see if your local CBS station is coming in clearly not tiling.
2. Reset your TV Guide through your TV Guide Menu, for more information copy and paste the link below. (What usually works for me is setting up the guide by putting in 99999 for the zip code then answer all other questions. After it says your TV will receive the guide in 24 hours then setup the guide as you normally would with your zip code).
http://www.rovicorp.com/support/13094.htm?link_id=topnav
3. Contact your local CBS affiliate engineer and see if they are having problems with the TV Guide transport stream i.e. SCTE 127 or VBI in MPEG
FYI if you get your service from a Cable TV company they will have to pass this information through their system commonly referred to as Passing PIDS.
Feb 08, 2010 | LG 50PB4D 50 in. Plasma HDTV
My tv has stopped working i trun it on and the
Sounds like a popped fuse or worse...a blown power supply.
Check with LG about service guides for you TV if you want to take a shot at locating and replacing these parts.
Good luck and be careful.
Dec 29, 2009 | LG 42PC1D 42 in. Plasma Television
TV Guide program does not activate or work. How
This sounds like you have a Samsung DLP TV with the built in TV guide system. Unfortunately what you are doing is the ONLY fix for it as there is no way in the system to deactivate the guide. The only work around is by using a cable or satellite box connected to composite or component inputs. This bypasses the internal tuning system therefore eliminating the internal TV guide system. Please take a few moments to rate my answer, Thank you..
Nov 19, 2009 | Samsung Televison & Video
The TV guide on screen no longer lists the tv schedule
Look online for the AVS Forum about TV Guide ON Screen (TVGOS).  there are lots of posts there about specific locations and providers,
May 18, 2009 | Toshiba RD-XS55 (250 GB) DVD Recorder /...
TV Guide System not working
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
Jan 24, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
TV Guide not working
I would check the website for your local PBS affiliate or call them and ask.
Apr 13, 2008 | Televison & Video
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Guide Plus issue...
Yep ... just figured this out myself today. When the Guide screen is up, navigate thru the options to Setup. Then select Review Options. You then get to a screen that gives you the option to turn of the system auto display. Good luck!
Aug 15, 2007 | GE 31GT740 31" TV
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Sony BRAVIA KDL52XBR2 Television Logo
163 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
