I have a Kenmore front load washing machine and it will not drain and the clothes come out smelly (like old water) what do i do?
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
I WANT TO CLEAN OUT THE FILTERS BUT CAN'T FIND THEM. tHE WASHING MACHINE IS 3 YEARS OLD AND IS WORKING BUT IS A BIT SMELLY AND CLOTHES ARE NOT AS CLEAN. I USE REAL NAPPIES AND USE THE MACHINE DAILY SO IT'S...
Remove lowwer rrear panel. locate and remove the large black hose fastened to bottom of drum, there should be a plastic filter inside the hose, if not, then filter is located at bottom front right of washer behind cover.
Sep 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Getting smelly, door has NEVER been shut between uses
Hello, Do you use liquid detergent, if yes,then this is the most likely the problem as there is chlorine bleaching agent in liquid powder and it has a tendency to leave the machine smelly after a while.
The cure is to do a "maintenance wash" (a biol water with no clothes or detergent in), once per month preferable twice.
Thanks
Jun 11, 2010 | Kenmore HE2 Plus Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Smelly clothes
It is because of the front loading door..
It seals shut - so after you do a load and shut it,, midew forms in certain areas..
Run a white load and use bleach..
After wash - (as all washes) leave the door open..
This might have to be repeted a few times - but it WILL go away..
Remeber to leave the door open after every load..
Have a nice day ;o)
Aug 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
SMELLY WASHER
pouring .5 cups of bleach directly into the machine works great for me. I have tried other techniques, but they all failed. (I HIGHLY RECOMMEND WASHING A LOAD OF WHITES AFTER THIS JUST TO BE ON THE SAFE SIDE!)
Dec 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load HE washer odor
How old is your machine? Mine is 5 years old, and I just started to get a "sewage" smell in my laundry room this weekend. I disconnected the water return to the sewer line and discovered lots of gunk in the hose, and the connector to the machine was completely dark green. I'm going to replace the hose, and trying to figure out if there is some sort of filter.
We only use He detergents too, so I guess this is something that just happens over time.
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
