Question about Refrigerators
I have a Kitchen Aid side by side , model # KSRD22FTST03. The fan in the freezer compartment runs all the time and I noticed frost build up on the back panel and in particular in the vent at the bottom of the freezer. Also, the water filter light blinks green all the time. So far the temps are good in both the freezer and fridge boxes. I also started noticing a loud rumbling sound sometimes just before the compressor shuts off. Maybe for 10-15 seconds. Thanks for your help
fridgetech
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
watugot
  • 290 Answers
SOURCE: Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Posted on Nov 11, 2007
  • 1314 Answers
SOURCE: FRIGIDAIRE FRS20ZRGD7 (SIDE BY SIDE) WARM FRIDGE/ COLD FREEZER HELP!
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system1.gif too if i can be of help or you need to know something just reply to this post
Posted on Mar 30, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
larryyb
  • 291 Answers
SOURCE: I have a kitchen aid
you may be able to get by with a start device for your compressor but if not you will have to have compressor replaced / if you like i can try to help with a start device / larryyb
Posted on Dec 01, 2008
I have a Kenmore Elite side by side refrigerator, the problem is the unit is not cooling at the top area of both the freezer and refrierator? the bottom areas are OK, I notice there is no air flow in the...
Is your fan inside the freezer compartment back wall towards the bottom is working. (Evaporator fan motor) ?
No fan... No circulation.
Fan may have failed or another common thing is failed defrost system has clogged up the evaporator coil and fan blade with frost. In this latter case, you will see white frost build up in the freezer back wall towards the bottom in freezer compartment.
Better call a local service technician. Little bit technical and hands on job.
Oct 23, 2017 | Kenmore Refrigerators
I have side by side KSRA25ILSS and last week I have noticed-freeser is working OK,but refrigerator-too warm .I reseted sys. couple times,but coudnt fix problem. What is my next step,please?
you will need to check the damper control and make sure the door is opening properly to allow the cold air in the fridge this damper is normally located in the back f the fridge top left side.
then you will need to check the freezer compartment and make sure there is not alot of ice or frost build up.You will also need to make sure the evaporator fan is running in the freezer comprtment.
If there is frost or ice build up you can use a blow dryer to defrost it then remove the back panel and defrost the evap coil.you will need to check the defrost heater and temp sensor be sure there are all working good.
Jan 04, 2011 | KitchenAid (KSRD22FKST) Side by Side...
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
Freezer building up with frost
Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
More info, let me know...
Charlie
Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have a Kitchen Aid refridgerator. My freezer
Hi, Check the rear inside panel of the freezer section and see if there is a frost build up. Also check and make sure the evaporator fan motor in the freezer is running.
If there is a frost build up, remove the rear indise panel and check the defrost heater and bi-metal switch for continuity. The bi-metal switch located on the top of the evaporator has to be tested while it is still cold.
If either of them show an open circuit, it will need replaced. If both of these parts show ok, you will need to replace the defrost timer/board.
Please let me know what you find and if I can assist you further.
Vic
Jun 28, 2009 | Jenn-Air JCB2280HES Side by Side...
I have a kitchen aid side by side model ksrs25qdwho3 . the refridge side is not cooling while the freezer side is working great. something frozen up? fan /blow dead?
Hi, Look in the freezer for a frost build up on the rear panel. Also listen for the evaporator fam motor. Please let me know and I can help you further.
Thanks
Vic
May 17, 2009 | Refrigerators
MSD2756GEB (Side By Side) Runs All the time
I went to the Maytag site and found a similar QA area and found a short article that talked about frost build up and/or blockage of any sort preventing airflow from the freezer compartment to the refrigerator compartment. They said this would impact proper operation of the refrigerator.
I emptied out the freezer after I inspected and found significant frost/ice in the upper right hand corner around the "scoop" that directs airflow into the refrigerator compartment. I took that off and removed all the ice build up (almost 1/2 blockage). I then removed the entire back panel and noticed that my refrigeration unit was completely iced up with significant build up around all the wires and thermostat.
I defrosted the entire unit with the aid of a hairdryer (at a safe distance so not to over heat anything) and then made sure my evaporator coils were all clean in the back and turned the refrigerator back on. (I unplugged it during the defrost operation.) I made sure that the fans worked both above the interior refrigeration unit and at the evaporator unit. Then I waited for the compressor to kick on.
Wallah! Everything so far was working so I put the rear panel back together in the freezer section, closed her up and waited to see what would happen. So far I've had to turn down the refrigerator section to around 5 and the freezer to about 4. The unit now seems to run correctly, shutting off after it runs for a while.
So I guess I'll wait and see how long this defrosting step works. Maybe the self defrost switch or something is not working and the problem will return in a month or so. We'll see..............
Feb 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
It's a Kenmore alright
Do you have any frost buld up in freezer compartment?if so sounds like a freezing issue.If no frost build up is your fan running in freezer part if not you may need evap fan or a manual defrost.Your fan may have ice stoping it from turning.If your fan is running you may need to pull off your start switch located on your compressor.Shake it around if you here noise like burnt parts in it you will need a start switch.And remmember never turn your fridge up full blast normal is good or you will freeze it up. Good luck:)
May 28, 2008 | Kenmore 60721 Refrigerator
Side by side kenmore
Have same problem on a 2 month old Kenmore 106.5794*700. side by side.
I can see ice / frost build up behind the lower baffle on fridge side. Does not seem to be any airflow from freezer side to fridge side. Freezer is extremely cold, it is about -23F. I read that 0F would be normal. Fridge side is warmish, running at about about +50F when it should be about +32 to +38F.
BTW: Ice pops started sticking to my tongue, thats why I noticed the unit wasn't working correctly.
I'm not 100% sure but I think the compressor is also running all the time as well. Either that or a Fan or something running. That kinda points to a stuck thermostat or some thing causing it to stick. I suspect that if the Freezer thermostat which is located in the Fridge compartment just may to rely on air flow from the freezer side via a duct, if this duct is blocked, the Freezer Thermostat misread the freezer compartment temperature and will always activate the compressor. Wish I had more details on exactly how the freezer thermostat works.
So after reading various forums on this it looks like a defrost issue causing the ice or frost build up or maybe just a faulty thermostat. Maybe there is a common circuit control board for these two functions?
As this is still in Warrranty I have a Sears Tech coming on Monday 14th Jan 08. I'll be interested to see what he does.
Dec 29, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
