Question about Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television
Circuit ng shut down(08) - Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television
Samsung giga sound system Fan ng is shutting the system down what do that means
Its cooling fan is not working. Might be damaged or have been strucked. In rare cases, a fan drive circuit fault can too cause this. Replace the fan, or repair the circuit. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Display [ng], means Not Good.
Dec 26, 2016 | Samsung Audio Players & Recorders
Hydra flame r.v. furnace works as it should several cycles then all of a sudden at end of cycle the blower fails too shut off and will not reignite until shut off at thermostat. Is circuit board causi
Not only can the circuit board be faulty but the high limit switch may be the culprit as the furnace may be overheating and the default function is to have the fan run until the temp in the combustion chamber is within normal limits. the fan switch itself needs to be checked for proper cut in and out function. Hope this helps.
Jan 04, 2015 | Heating & Cooling
Error code 08
Good Morning Friend,
I understand that you are receiving a 08 error code on your Electrolux dryer, model# T4530. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux Dryers
2005 Honda Dio electric starter hindi gumagana
Hi, Nashana1712 bago subukan ang anumang mga de-koryenteng sangkap sa Simula Circuit ito ay "PAUTOS" na mayroon kang isang ganap na sisingilin baterya ng 12.5 volts o higit pa at maaaring pumasa ng isang wastong "LOAD" test kung kinakailangan, maaari kang magkaroon ng isang paunang pagbabasa ng 12.5 volts o higit pa ngunit maliit o zero amperage, ang baterya ay may mali at dapat mapalitan. Ang mga uri ng baterya ng AGM ay nahuhulog sa sitwasyong ito nang higit pa kaysa sa lead-acid na mga baterya.
1. Pagsiklab Hindi lumipat sa "ON" na posisyon.
2. Engine Run Lumipat sa "OFF" na posisyon.
3. Ang Engine Run Switch ay "FAULTY" o corroded.
4. Suriin ang mga terminal ng baterya para sa pinsala o kaagnasan suriin ang mga kable ng baterya sa "BOTH" na nagtatapos para sa maluwag, nakakagambala, o sirang mga konektor, "INSIDE" at sa labas ng cable harness, magsagawa ng connector na kumikilos ng pagsubok at suriin ang mga cable na may isang ohmmeter.
5. Ang sensor ng anggulo ng bangko ay nangangailangan ng pag-reset o ay may sira.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Buto na mali ang starter.
9. Malagkit na kickstand, klutch, neutral safety switch.
10. Kailangan ng alarm ng seguridad ang isang pag-reset.
11. Starter relay, solenoid, starter motor o circuit wiring may sira. 12. Nabigo ang starter armature o field coils.
13. Ang pangunahing fuse o circuit breaker ay maaaring tinatangay ng hangin o may sira.
14. Faulty ignition relay.
15. Ang electric starter ay nagtatrabaho ngunit ang starter clutch ay nabigo.
16. Suriin ang mga code ng problema sa engine.
Para sa karagdagang impormasyon tungkol sa iyong isyu at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin o pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw. Scooter Troubleshooting Scooter won start All about Scooters
24 So Your Honda Scooter Won Start
Honda SK50M Dio Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda SK50M Dio SR 2000 Owner Manual
Apr 03, 2012 | 2005 Honda Dio
JVC RX-6042S shuts down after 5 seconds
It will be one of the transistors that regulate the lower volatges (5V, 12V...)
I ffixed mine. the heatsinking on those transistors is pathetic, and its no wonder they dont last.
Mine was the 5V circuit, which also supplies the DSP board. so if you are getting a DSP NG, that could be that as well.
Check Q1434 and Q1404. if one is faulty, it drags the other one down with it.
Good luck.
Dec 27, 2009 | JVC RX-6042 Receiver
Ang question ko lng kc bumili ako ng washing machine last sept. '08 then netong last dec. '08 last week nasira n agad, this january i call the assistance of the american home technician kc naka under 1...
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Auto shut down
So I had to send the camera back to have it fixed. It was the only solution I could think of. I actually had an extended warranty plan so I sent it to Mack Camera and Video Service in NJ. The repair order was placed on 7/8/08 and I received the camera back on 8/18/08. It did take awhile, but they did fix the problem. They first let me know they had to order the parts then they ended up having to send the camera back to the manufacturer for repair. They ended up replacing the circuit boards, updated firmware, and cleaned and checked all functions. So, though it took awhile, it is fixed and working fine.
Dec 23, 2007 | Casio Exilim EX-S600 Digital Camera
Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television Logo
215 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
