Question about Sharp AR-235 Copier
How i can fix it Fault U2-40 - Sharp AR-235 Copier
    President:
  • Sharp Master
  • 1,447 Answers
how i can fix it - k15yacewaaaabjru5erkjggg==
CRUM error.You must change toner chip
Posted on Mar 25, 2011
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
How do i fix my 1994 isuzu mu overdrive
for an auto transmission it will be a servo/solenoid fault or a wiring connect fault
run the fault codes
Aug 31, 2015 | Isuzu Cars & Trucks
My jbl mpro powered by crown is in fault mode how do i fix that
You may have a bad amp a fault could be a output trans or a speaker that is shorted the plate amp may need to be fixed!
Nov 05, 2014 | JBL Audio Players & Recorders
How do I fix a fault
Not a problem. I have noted that the F4 Ignition fault you are getting is with a Glowworm 18si boiler.
This relates to the burner system and will need a gas licensed technician to fix it.
I am providing you reference to an Installation and service manual to help you understand the likely fault but under no circumstances is this an invitation to attempt to fix the fault unless you are a qualified gas technician. Refer page 37 in the manual.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Glow%20Worm/24ci-18si.pdf
Aug 13, 2014 | Dishwashers
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Feb 03, 2010 | 2002 Audi A4
Check engine light
The check engine is a fault indicator, it will stay on until the fault is fixed and a certain number of miles driven to check that the fix was successful, it can' t be reset, you can erase the code with either a OBD 2 scan tool, or in some cases by disconnecting the battery for 1 hour, but if the fault is not fixed the light will come back on in short order. Very seldom do you fell anything different unless the fault is transmission related.
Sep 26, 2008 | 1999 Toyota Land Cruiser
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-235 Copier Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
