Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
For an ingersoll rand 30T 242-5c air compressor I need the head bolt torque specs
  • 98 Answers
SOURCE: I need the head bolts torque specs for an
With Graphite gaskets the torque is 34 lbs.
Posted on Jul 21, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
  • 84 Answers
SOURCE: Torque specs for the head bolts on a GMC compressor
There are surely specs, but you should be able to feel the right tightness for these bolts. It's when the threads just begin to bend-- if you don't know this feeling, and can't find the torque specs, use 15- 20 ft. lbs.
Posted on Nov 24, 2009
  • 84 Answers
SOURCE: what is the torque for head bolts on my ingersoll
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Posted on Nov 27, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
Torque on ahead bolt
the torque must use is 75ftlbs. that is for the air head.
hope can help.
Jan 30, 2014 | Ingersoll Rand - Rand Type - 30...
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
I would like the head bolt torque specs, just to retorque after startup
to be honest I always just snugged them down. Very seldom used a torque wrench. You need to check these often due to the fact that between the cylinders is a weak place for the head gasket. If you do blow one get you some garlock or similar gasket material and make a gasket. will work better and last longer.
Nov 27, 2011 | Ingersoll Rand SS5L5 Ir Electric...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
Nov 23, 2009 | Ingersoll Rand SS3F2 Gm Ir Portable...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
331 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
