Question about Garden
I locked my bedroom door with my keys in the room
  • 2,841 Answers
Look closely at the door knob and you will see a very small hole in the middle of the door knob. Use a piece of stiff metal such as a heavy paper clip straightened out and push it into that hole. that will unlock the door to your bedroom if you have a normal bedroom door lock.
Posted on Mar 25, 2011
How do i put a lock on bedroom door
Go to home depot and buy a privacy lock.
Jul 29, 2015 | Building Materials
I have an interior lock set on door to bedroom ; locked out keys on other side. Help
Use a credit card and push it in at the latch, between the door and the frame holding the door away from you, while pushing the card inward onto the latch ramp wiggle the door in and out until the card slides all the way in and pushes the latch into its receiver and door will open.
Nov 23, 2014 | Locks & Locksmithing
How do i break into a locked bedroom door?
look for a small whole like screw whole twisting it around should open it did it before allot of times.
Oct 05, 2013 | Locks & Locksmithing
I have fitted a door knob to bedroom door. This lock has a key. The problem is that I cannot lock the door and go out as it does not lock. The key seems to release the latch when the knob is depressed...
hello joan. check to be sure that the door properly latches when it opens and closes with out locking it at all. sometimes the latch does not easily and freely go into the latch hole as the latch hole needs to be adjusted. joe
May 18, 2011 | Locks & Locksmithing
How do i change the panel voice feedback on GE Simon 3 to say something different? For instance, instead of it saying "East Bedroom Window Open", can I change it to say "Blue Room Window Open"? I have 5...
Unfortunately the Simon 3 has a limited vocabulary. The alarm company probably did the best they could. It will tell you the zone number 1-24 but you may already have the best audio descritption you are going to get.
AlarmProfessor.net
Apr 07, 2010 | GE Security Simon 3 Wireless Home Security...
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
Tran A/c installed last summer
It's the ducting that causes the problem. But if the old unit wasn't as bad, did they install a smaller unit to save on money? It is possible, some companies do this to make more money. Sad but it is true. A return added to the room would help but if they can run a return, then they can add another duct or reduct the room as well. Sounds like someone is trying to sell you a story without fixing the issue. Tell them that they don't need to add an extra run, tell them to change the size! Also, make sure that if the run is longer than 25 feet, the ducting has to be stepped down in size to increase valocity to the vent. For example, you have a 10" duct running for 25' and then you step down to 8" the rest of the way unless that run is more than 25'. Hope this info helps!
Apr 02, 2009 | Heating & Cooling
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
