Question about Samsung PS42P4AX 42 in. HD-Ready Plasma Television
The tv color going more red green and i went to the shop and it have promblem the main system.were can i find main BN94-017176 THANKS
  • 1,591 Answers
This part is not common because it's specific to this TV.
You will have to order it from a samsung authorized service depot or from samsung directly, or you will have to take the unit into a samsung authorized service center if the part is not available to consumers.
Posted on Mar 25, 2011
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
Just do a hard reset to this set and check. To make it a hard reset, unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If this do not help you, the main board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 01, 2014 | Proscan Televison & Video
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Jan 02, 2011 | Philips 42PFL3704D LCD TV
50PL9126D/37B 50 in. HDTV DLP TV: the red green and blue colors dont align properly...
Your convergence is out. If it's just out a little, you can adjust with your remote or with older sets there are knobs. If it's way out then your convergence block went out and you'll need to replace it yourself if you're technically adept or take it into the shop for repair.
May 17, 2010 | Philips 50PL9126D/37B 50" DLP TV
My tv picture and color just went out
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
May 09, 2010 | RCA HD52W56 52" Rear Projection HDTV
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Colors on tv are blurry, almost like when you watch a movie in 3-d, the red and green colors seem to go around the main image
Nov 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV has sound but the screen looks like it is going out has double, colors green, yellow, red. Went off by itself once. Wavy looking. Smelled burning in back, when it went off by itself.
you're describing a power convergence amp problem, usually starts out at random color shdes or gohsts around the images more noticeable on scenes with letters or horizontal and vertical lines. the power amps overheat and sometimes will short out causing the fusible resistors to burn out. these amps are usually mounted on heavy metal dissipation units in one of the main boards.
Jul 30, 2009 | Samsung Televison & Video
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Samsung PS42P4AX 42 in. HD-Ready Plasma Television Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
