Question about Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System
I feel that the 'normal' background hiss is a problem that I would like to minimize with the sennheiser IEM 300. I'm currently using the IE 4 ear phones. Would a different/better earset with maybe a slightly higher impedance help reduce the hiss? Note: The background hiss in question is that with the transmitter off and the receiver volume set to minimum. Thanks Brian
  • Sennheiser Master
  • 5,603 Answers
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Posted on Mar 25, 2011
What could be wrong?
Put it in MONO mode.
You can also make a cable where the TIP and RING are wired together....
Oct 09, 2017 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
We have a problem with the lead that plugs into the receiver, and it has a shrowd over it that screws it in tight. the other end has a 90 degree angle with a mini plug into our camera, can we buyt that...
The lead is probably special. Your choice is probably to go to Sennheiser parts or make your own. The connectors are available. It sounds like the one plug is a 1/8 inch with locking ring... Those are hard to find. Contact Sennheiser to find their part number. 1-877-736-6434 ext. 1
Sep 05, 2011 | Sennheiser EK 300 IEM G3 Portable Personal...
The ew 3000 iem (brand new) is stuck on mute. Tried everything to no avail. Ideas????? Please Help!!!???!!!!
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards, Tony
Mar 24, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
How do I un mute the pack
It looks like the mute function is only available from the menu... not very user friendly at all... I guess they figure the performer doesn't need to mute easily or quickly... Volume control I suspect is all that is readily availab;le at the pack to quickly mute.
Mar 13, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Disturtion in one left channel and bad quality in right channel
Make sure you are NOT overloading (clipping) due to excess signal into the transmitter end of this unit. Reduce the gain INTO the fixed unit and see if the sound improves.
Feb 23, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Some Headphones have an inherent hiss noise when they are connected to my wireless sennheiser EK 300 IEM G3 receiver. It seems to be a problem particularly with high-end IEMs which are highly sensitive...
Hiss is a problem of statistical noise in electronic devices due to the laws of physics plus circuit design.
One thing to do is to improve the signal to noise ratio (SNR) by properly setting gains. It is POSSIBLE that the IEM's you are using are too low impedance for the receivers resulting in you having to use excessive gain at the receiver. Your receiver gain control should not have to be above 60% of the way up. If you are above that, the ear buds are probably lower impedance than the receiver is designed for... and remember the manufacturer will LIE on the capability of the thing they are trying to sell.
The receiver is speced at 32 ohm drive... IF your ear buds are less than that impedance, they are NOT suitable. Conversely if they are too high, thaat will ALSO cause you to turn up the receiver gain too much and result in poor SNR.
You want to make sure the transmitter is being driven at line level so receivers get adequate input audio so gain doesn't have to be run too high.
Jan 04, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
My swr workiongpro 15 suddenly has a very noticable hiss even when the amp is muted, and when I play the high end is more prominent than it was before.
If you are having the treble/high turned up there will be hiss. This is due to the statistical noise in electronics, including semiconductors. It is a matter of degree. The hiss should be 30 Db below your program level or so.
It is very common for one to change settings and suddenly start to notice hiss or hum at certain settings.
IF YOU CAN, go to a music store and COMPARE the amp to yours at the same setting with NOTHING plugged in. (cables and guitars can generate hiss or other noise themselves).
There is very little in your amp that would have changed to suddenly start generating hiss, so FIRST compare. This will minimize the chance of spending money at a shop to be told it is normal.
Sep 14, 2010 | SWR WorkingPro 15 200 Watt 1x15" Bass...
Hiss
If trim controls or gains are set near maximum, HISS is normal as electronics generates a thermal type noise.
If gains are set in normal operating area, the noise SHOULD be minimal.
Other sources of interference like nearby radio transmitters, welders, arc lights, etc. can create noise.
Start with ALL gains turned down and find which if any cause the noise to be unacceptable.
MAKE SURE all power to this and ALL the other connected equipment come from a single receptacle to avoid ground loops.
Jan 02, 2010 | Yamaha Mg82cx Stereo Mixer
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
Sennheiser ew 300 IEM G3 In-Ear Wireless Monitor System Logo
274 people viewed this question
Top Sennheiser Music Experts
Michial Gueffroy
Are you a Sennheiser Music Expert? Answer questions, earn points and help others
