Question about Wheels, Tires & Parts for Cadillac SRX
I have a 2006 Cadillac SRX V6 - original tires P235/65 - R/17 103H front and rear tires are P255/60 - R/17 105H. Why the difference in size and do I need to replace them with the same? The rotation process seems weird and what will it do to the handling and ride if I purchase all 4 tires the same??
    Master:
  • 403 Answers
Should not be a problem if all are the same. Let me explain how to read the numbers for you. ok, front tire, 235/65-17. first the easy one, 17 means 17" wheel. now 235/65 refers to width and sidewall, the width is 235 cm across, and the sidewall is 65% of that size. hope this helps you.
Posted on Mar 25, 2011
Where is my dipstick located on my 2006 srx cadillac
Hi Amber,
I presume that you want to change the oil on the Cadillac. The link below will tell you how to change the oil, where the drain plug is and where the filler is a. It will tell you where the dipstick is.
Oil Filter Change Cadillac SRX 2004 2009 2006 Cadillac SRX 3 6L V6
This is a good, clear video.
Mar 04, 2015 | 2006 Cadillac SRX
Firing order for Cadillac srx
if its the 3.6 v6 staring from the front of engine passenger side head is 123 driver side head is 456 if its the 4.6 v8 it is front head 2468 and back head is 1357 starting from the left to right
Jan 13, 2015 | 2006 Cadillac SRX
2005 cadillac front end thumping noise
That's a tough one since there can be so many different causes, starting with something loose under the hood to a problem with the suspension (sway bar links, control arm bushing, ball joint, strut mount, motor mount, etc etc). This can be a serious safety issue, so if it were my vehicle, I would first get to a dealer or alignment shop right away to have the front end suspension, tires and wheels checked.
Sep 25, 2014 | 2005 Cadillac SRX V6
Can I put the same size tires on the front and back of 2006 srx
I had the same question and I finally did replace my tires with the same size and I am very happy with the results. The reason they are different sizes was to increase the performance of the SRX. I have 18" wheels and put on ( 245-60R-18 Michelin Lattitude) tires. The reason I selected this size was to minimize the speedo error to 1 mile per hour. I did that by going on line to a tire calculator and compare the original size to the replacement I selected. Now, depending on your rim size you might find that you may have to select a different tire then I. The rule is to keep the spreedo error under 3 MPH. The ride quality was greatly improved with my selection.
Jan 09, 2013 | 2006 Cadillac SRX
2007 cad SRX right rear has flat tire 255 60R17 can I use the spare tire? Is it a full size spare tire?
If the vehicle came with a spare tire then yes you can use it. As to whether or not it is a full size spare tire I wouldn't be able to answer that, as on some models a full sized spare is an option and I have no way of knowing if that option was purchased or not.
Jan 06, 2011 | 2007 Cadillac SRX
Bought a 05 Cadillac SRX. Manual says tires sould be differnt front and rear - all trires on the car are new 255/55R18's. Should I bring it back to the dealer?
Hello, If you will check on the drivers door fram there should be a placard telling you the size and pressure and if I'm correct they should be directional tires. Yes I would take it back to the dealer. Cadillac recommends the proper tires for thi car
Sep 06, 2010 | 2005 Cadillac SRX
On a 2005 cadillac srx, v6, how are the cylinder label 1-6?
The firing order is 1-2-3-4-5-6. Cylinders are located on the driver's side front to rear of engine 1-3-5 passenger side front to rear 2-4-6.
Aug 11, 2010 | 2005 Cadillac SRX
The rear Drivers side axel has play.
I would certainly replace the axle with play. But this may not be all. Could be wheel bearing as well.
Oct 18, 2009 | 2004 Cadillac SRX
Slip Control Coming on Infinity G35 6 Speed Coupe with New Tires
you have a computer for your control on your car. It is set up so only the factory front and rear tires sizes will work, any change, it picks it up. this should solve the problem.
Aug 28, 2009 | 2002 Cadillac Deville
Wheels, Tires & Parts for Cadillac SRX Logo
337 people viewed this question
Top Cadillac Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
John Totten
John Totten
Brian Williams
Brian Williams
Are you a Cadillac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
