Question about Loewe Televison & Video
Hello, I have a Loewe Mimo 28 (Q2500B chassis) which blows the main MOSFET in the switch mode power supply (Q624) after a couple of weeks of use. Can't see any other faults. Any ideas?
  • 1 more comment
  • philip988 Mar 25, 2011
    OK, that's general advice for switch mode power supplies, but I was looking for advice and experience specific to this model.
    The FET lasts for a couple of weeks when replaced before it blows again. Do you think a faulty electrolytic would show this kind of behaviour?
  • philip988 Mar 26, 2011
    Thank you. Not the specific experience I was hoping for, but good general advice.
  • 1,591 Answers
Look for bulging or leaking capacitors.
There's been a lot of capacitor failures in all kinds of devices lately.
Since you know what a MOSFET is, I'll assume that's really all the explanation you need to go looking for the damaged compunents.
Check most carefully on the power supply and inverter boards.
Posted on Mar 25, 2011
  • 1 more comment
  • Norman Skinner
    Norman Skinner Mar 25, 2011
    In general, all switching mode power supplies operate on the same principal, and power supplies in monitors (especially large flat screens) or all makes and models (most notably Samsung) as well as computers etc have been failing all over the place because someone got the electrolyte formula wrong, and several companies copied the formula - so it's not even capacitor manufacturer specific. Even amplifiers that don't have switching supplies are falling victim to the improperly made capacitors. Oddly these caps usually just outlive the warranty period. I'm sorry if I can't point you to a specific component or capacitor number, but it could be any number of them in the power supply, and often they go in groups.
    I apologize if the answer isn't specific to that brand and model, but it really is most likely the issue, and you'll have to look around the supply module, and possibly even the other circuitry for these things because it's not always the same ones that fail, even in specific makes/models of devices - some capacitors will simply fail before others.
    Again, I apologize if this information wasn't helpful to you.
  • Norman Skinner
    Not a completely faulty one, but a failing one.
    As the capacitor starts failing, frequencies will shift which can cause all sorts of faults including increased impedance and overloading or shorting outputs.
    When the load on the mosfet reaches it's tolerance point, it will last a while, but eventually fail.
    Failing capacitors can cause all sorts of issues, because their capacitance may vary with temperature too, so if say you use the TV about 2 hours a day, but much more on weekends, the chances of a weekend failure are much higher, meaning it might last 1 to 2 weeks, eventually only 1 week, and at some point it just won't turn on anymore.
    Anyway, you did say "any ideas" and that's my idea. It certainly won't hurt anything to go looking for bad caps. If I tell you to replace a specific component without being able to diagnose the board "hands-on" and you spend money on that part and the time to install it, and it doesn't work, I think you'd be much more upset than if I send you looking for what is most likely the issue - looking costs nothing but some time.
    Something somewhere is obviously operating at a degraded state, not a failed state. If something had failed completely, either the mosfet would blow immediately, or it'd blow a fuse or just not turn on at all.
    The only other possibility I could think of is if this mosfet is on a heatsink, the heatsink compound might need to be replaced and if there is a fan to cool the heatsink (or any other part of the unit) that the fan may have failed or is failing.
  • Norman Skinner
    At least that's all I can think of without being able to see the board since I don't have a schematic for it and can't put a meter to it myself.
My TV still turns on and off, but there's no picture or sound. How do I fix it?
The modern TV has two power supply sections. The first is a low voltage +_5 V, very low energy consumption, to keep the remote control functions live. The main power supply seemed to have failed and could be very difficult to fix as it is a energy efficient switch mode supply. Normally the switching transistor or MOSFET fails first and the blows a fuse. Depending on the root cause, replacing these could restore its function.
Nov 18, 2015 | Televison & Video
I have a Loewe Concept 32 that makes a buzzing noise when switched on. The picture and sound are otherwise fine but a variable frequency buzz predominates
Check for any core loose [SMPS] transformer at its main power supply regulator board. Contact any service technician. This is a very dangerous part to touch. Gopakumar Gopalan Google
Jan 02, 2015 | Loewe Televison & Video
I get problem with my loewe television concept L26 that remains stand by even you switch it on using remote. at the power supply circuit only 5V can be seen at connectorW652 and connector W651 no vol
Just understand, that the 5V supply you measure comes from the power supply is used for standby and power On switching purpose. As far as this supply voltage is OK, the fault must be to its main board, because, from the main board comes the power up start voltage back to power board to initialize its whole working.
Check the main board. The power supply regulator board is now Ok; otherwise, you can't get this 5V supply line active. Contact any service technician.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 25, 2014 | Loewe Concept L26 26 in. LCD TV
TV LOEWE 8784. Died SPP11N60S5 in the power supply. After replacement of the MOSFET the TV worked for a day then next morning it died again on a start. This way were killed 3 MOSFETs. What could be the...
Possible that when the MOSFET'S were changed the Switch mode oscillations were not proper and so the drivers were driven too much to fail.
It will be best to replace the whole power supply if the mosfets are heating up more than required.
Also replace all the electrolytics and check the SM transformer after the mosfets are replaced and before switch on. Check also the load on the output , if there is any short or leakage on the drive output .
Aug 04, 2011 | Televison & Video
Samsung 953BW monitor alwyas goes to blank screen
first u will check the signal cable then check crt base [ if lot is arcking ok] replace crt base check filament volt,g2 volt,g1 vot .....etc,then u r chek 5v reg ic in supply out on smps,eprom chip and check H OUT transistor base voltage u r problem not solved about this information pls ask again to me may i help u.......
May 16, 2008 | Computers & Internet
Bush TV Dead MODEL: 5693D
switch mode power supply? it has a in or primary side and out the secondary side of a switch mode transformer.
check the driver IC that runs Q102 it makes a oscillation that Q102 amplifies. now the secondary if has a short will blow the Q102 look for shorted rectifiers in the secondary and fuse resistors that are open, even go far downstream and check the HOT for short.
Feb 15, 2008 | Televison & Video
Will not switch on
If the sound is like an electrical arcing from the back left as you look at it the probable cause is the LOPT (Line output transformer) get this repalced and the set should be good.
If it as a clicking from just behind the front controls, the 5V standby transformer needs replaced.
Nov 01, 2007 | Loewe Aconda ACO9303 30" TV
Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Aug 08, 2007 | Loewe ARC332 32" TV
Televison & Video Logo
109 people viewed this question
Top Loewe Televison & Video Experts
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
