Question about JVC SR-MV55 DVD Recorder / VCR Combo
Have 2 units both just flash "loading" and will
    New Friend:
This happened last night on my new-to-me JVC SR-MV55. Even powering it off for five minutes didn't help. It apparently crashed during dubbing (couldn't create more than 9 chapter codes?). Manual suggested holding down Stop and Power after powering it down. But no matter how long I held Power it wouldn't stop flashing. But I tried Stop/Powwer for a bit, nothing seemed to happen, then maybe 15 seconds later it restarted "WAKE UP'".
Posted on Mar 15, 2013
Trying to play flash drive in USB port on stereo
Make sure that the music files are indeed mp3 format. An iPod will play several different formats but most av head units only play mp3. A lot of the songs that are downloaded from iTunes are actually mp4
Jun 08, 2014 | Pioneer DEH X3500UI - radio / CD / MP3...
Tip
Play flash(flv/f4v) videos on iPad 2
The newly released iPad 2 does look like a very well-designed and beautiful device. It may be used to search the Internet, watch movies and videos, listen to music, use art programs, read/send e-mail, read e-books, play games, keep a calendar, watch TV, use maps, or to look at and organize photos. The iPad, however, won't run flash content at all. That means you won't be able to watch videos from Hulu and the adobe flash is kept away from your touch. Still you could watch the flash videos downloaded from Youtube or Hulu on iPad------Pavtube FLV Converter could convert flash videos (*.flv, *.f4v) to H.264 or MPEG-4 encoded videos that are compatible with iPad. The following guide tells how to <a href="http://wannasoft.com/Pavtube-Video-Converter/">convert flash videos to play on iPad 2</a> with Pavtube FLV Converter. <br /><br /><br /><b>Step 1. Run <a href="http://wannasoft.com/Pavtube-Video-Converter/">FLV to iPad Converter</a></b> <b>and load in flash videos. <br /></b>First, you Install the FLV Converter and get your FLV files ready,<b> </b>run the app<b> </b>and click "Add" button to import FLV files to the app (or simply drag the source files to file list.) Double-click on it if you'd like to preview a file or take some snapshots. <br /><br /><b>Step 2. Set output format to be compatible with iPad</b> <br />You will then tick the format bar and choose an appropriate format for iPad. MP4, MOV, M4V encoded with H.264 and MPEG-4 are available. Specify output format and next output path. Click on "Settings" button in case you wanna change its codec, bitrate, size, frame rate, audio channel, etc. For example, set audio codec as AAC. <br /><br /><img src="convert-flash-video-to-play-on-ipad_clip_image002.jpg" /> <br /><br /><b>Step 3. Convert the FLV, F4V videos</b> <br />When all these are done, you can click "Convert" button to start. If you'd like to put some flashes into one file, simply check the box "Merge into one file" before clicking "Convert". After conversion finished, you may sync the converted video clips to iPad for playback.
on Mar 11, 2011 | Computers & Internet
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
Lt-32d200
What you are describing is a bad/damaged optical unit in the player--some are sold but only as a complete unit.
Mar 20, 2012 | JVC LT-32D200 LCD TV
When loading/playing farmville I get "lots" of error codes and "hangs up" big time. One code in particular is Error 1502. During play, I receive others
Good Day!
Please download and install latest version of Adobe Flash Player. It will remove those errors when loading the farmville application.
To download, please go to: http://www.adobe.com/support/flashplayer/downloads.html
Good Luck and please let me know how it goes...
Aug 12, 2011 | Facebook Social Network
My unit is a DVP3140, purchased 2006 or 2007. As soon as I got it, I changed the code to region 0 so that I could play the DVDs I bought when I lived in Italy. It worked great for about 3.5 years of...
By changing to Region 0 you've changed the Laser control and subsequently the Laser is failing earlier than it would have done under normal operation.
The only solution would be to replace the Laser which is not normally cost effective and often unavailable anyway.
CDs may still play for a period of time as these require less power as there isn't as much information to read as a DVD.
May 29, 2011 | Philips DVP3140
Fail's to start. "DL" and "F" flashes, no matter
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore Elite 45986 Front Load Washer
Samsung BP-1500 problems When I tried to update the F/W to V 2.0 081106_21_XSA.RUF I encountered a problem. I now cannot play any dvd's and my Samsung LCD cannot connect with the player. this is what I...
Just contacted manufacturer with same problem.....your unit needs to be updated....check website...can be done with flash drive or burn a cd
Dec 19, 2008 | Televison & Video
JVC SR-MV55 DVD Recorder / VCR Combo Logo
135 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
