Question about Cycling
How to increase resistance on Blackburn Tech Fluid Trainer? I know it is supposed to increase with rpm's, but I am not a strong rider and I just rode 90 minutes in my biggest gear with only moderate effort. I can't get the resistance strong enough to climb. Thanks for your help!
    Guru:
  • 347 Answers
Fluid trainers work by providing resistance that increases as your effort increases, much like riding on the road. There is not a switch or lever to increase the resistance with this specific trainer. So in short you have to put in a bigger effort to get more resistance. Putting in more effort and increasing your Cadence (rpm's) will provide a harder resistance and will decrease your duration attainable. This is OK. One of the benefits of using a trainer is that you can get more accomplished in less time.
Posted on Mar 25, 2011
Blackburn TECH MAG 6 indoor TRAINER gets hot and makes noise after I use it for about 15 minutes
What type of tire are you using? How tight have you set the tire on the unit? Make sure you tire is inflated to it max level and only tighten the wheel against the tire until when you jerk on it it doesn't slip. Heat on these units is normal from use.
Dec 01, 2016 | Cycling
I have a pro tec sports pts windtrainer 800 & can't figure out how to make it pedal harder, please help
There is no way to make a wind trainer harder as it uses fan blades and air for resistance. You could try shifting to a harder gear on the bicycle. If it still isn't hard enough, you will have to go to an adjustable mag resistance or fluid trainer.
Mar 13, 2014 | Stamina Products Cycling
Do you put the bike computer on the front of spokes or back
Traditionally the front. Some units are wireless, but have a minimal range and cannot transmit through the riders obstruction. Most cabel harnesses will route up the front brake line.
If you are desiring it to work on a "trainer", its best to invest in a cadence (crank arm rpm)sensor. Your speed is not as important on the trainer, but monitoring your cadence in relation to your heart rate is key.
Jan 01, 2013 | Schwinn 12 Function Bike Computer
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Apr 04, 2011 | NRS Kinetic Road Machine Trainer
Could a hardtail be used for touring, would it be able to carry reanonably heavy loads?
There is no reason to doubt the physycal load-bearing capacity of a bike that isn't built stupid-light to begin with. Your wheels should be strong enough for the added weight. Get some good road-worthy tires but keep the size large enough for rim protection.
You won't like how it feels if you stand and pedal but it can be done. I've toured on full suspension. I find a mountain bike set up for the road frees my eyes for scenery instead of scanning the pavement for pebbles and cracks.
Get a Blackburn or comparable rear rack and slap some panniers and a rack-pack on it. I'd also consider adding bar-ends for variety in your hand positions as the miles pile up. I even add an aero bar for the long descents of mountainous areas.
If you can find a front pannier or rack system that will work with your fork you might opt for that instead or in addition to the rear rack. Your weight distribution should not all be on the rear. I find front panniers slow the steering down in a pleasant way, making rider input smoother and resisting sudden swerves that can make you loose front traction.
Added weight is not the drag on the actual riding experience that it is on paper. Once you're in motion you tend to keep it, so it pays to rider smarter and plan for red lights by timing your arrival for the green so you don't have to invest all that energy into accelerating again. Tandem riders catch onto this in time for the same reasons. Loaded downhills are a thrill.
Test ride the loaded rig before your trip. Do some long hills just so you know how to adjust your effort. Have fun.
Feb 02, 2011 | Marin Cycling
Skewer is missing from used Blackburn Tech Mag 6 bicycle trainer. Is it needed or can I simply mount the bike using the quick release skewer already on the bike?
I don't see a skewer supplied with the trainer. If the mechanisms for securing the bike axle are intact you can use your original skewers. I'd look at how well they mate before committing though, especially if your skewer is after-market or proprietary design. The old school chrome skewer with a rounded head is the best. The first one shown here is the universal design.
http://www.sheldonbrown.com/skewers.html
Aug 17, 2010 | Cycling
Skewer is missing from purchased used Blackburn Tech Mag 6 bicycle trainer. Is it needed or can I simply mount the bicycle using the quick release skewer that is already on the bike?
Go to your local bike shop and get one, or have them order you one. It is better to use the one that comes with the trainer, they are not that expensive
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Cycling Logo
115 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
